is there gasket in 2-1 termi? - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old May 11th, 2010, 1:15 pm   #1 (permalink)
where it meets the pipe? im blowing black suit and hear the fap fap fap on decel, also have harsh blap blap blap on low rpm WOT instead of the thump thump thump music. any suggestions?
03 m916 dark
trippin green is offline   Reply With Quote
Old May 11th, 2010, 5:07 pm   #2 (permalink)
Banned
Images: 19
As far as I know, no gasket.
If your concerned about an exhaust leak just stick your hand near the join when bike is idling and you should be able to feel it if there's one there.
Because this is a relatively new fitted exhaust I'd say the clamp just needs tightening up some more.
Tard is offline   Reply With Quote
Old May 11th, 2010, 5:48 pm   #3 (permalink)
hyperdookie's Avatar
Images: 9
There is a gasket, more like a crush washer , on each header pipe where the collar meets the head.Two new ones are supplied with the 2-1 kit.During my install I was eventually able to peel the the original off the head with a pick but it was a bitch. When it came off, it looked perfect so I decided to leave the other one on the other head. I wonder if maybe you have two stacked on top of each other.
is there gasket in 2-1 termi?-img_0482.jpg   is there gasket in 2-1 termi?-img_0483.jpg
Old May 11th, 2010, 6:09 pm   #4 (permalink)
londin's Avatar
I have the same, thought it was just the bike!! Better check for double or non of the gaskets!!
londin is offline   Reply With Quote
Old May 11th, 2010, 6:28 pm   #5 (permalink)
definitely not at the head. its at the joint going into the muffler. there is no leak at the heads, those are spotless and tight. there is no leak where the head pipes go into the collector either.
took it apart today, seems its a just a double layer joint. a loose one. there is no clamp. just a spring keeping it seated. so i took a 3/16 strip of header wrap and stuffed it into the seat, no leak as of now, will check it out after a nice ride.
03 m916 dark
Old May 12th, 2010, 7:16 am   #6 (permalink)
commute to work, sounds amazing, so much smoother, seriously music. will also report back after a good excercise of the engine.
03 m916 dark
Old May 12th, 2010, 8:25 am   #7 (permalink)
So you just stuffed it into the seat after the pipe was already fitted? Mine is doing the same thing, I was thinking of adding another a spring and hangers for it on the outside of the pipe or having a muffler shop I use do a couple cuts and weld some flared fittings for v-bands. The kit 2-1 pipe where the muffler meets leaves a lot to be desired.
2009 Ducati Hypermotard 1100 w/ DP Termi 2-1 Kit
singlefin is offline   Reply With Quote
Old May 12th, 2010, 10:24 am   #8 (permalink)
no i wrapped it around the inside pipe, and when i pushed the muffler on it pushed the strip of wrap in. was thinking about the second spring myself. and figured some flair or crimp work would work better and be cheaper.
looks like this now
03 m916 dark
Old Jan 20th, 2011, 10:31 am   #9 (permalink)
sm171's Avatar
I don't have my instructions for the 2-1 install anymore. Can anyone tell me if the torque settings for the retaining nuts are the same as the stock headers? Thanks.
Mike
08 Ducati HM1100
08 KTM 450 EXC-R
sm171 is offline   Reply With Quote
Old Jan 20th, 2011, 4:55 pm   #10 (permalink)
Raiden's Avatar
I used an exhaust cement on all pipe connections with good results. You can also use high temp. silicone.
2008 HM1100S
Raiden is offline   Reply With Quote
Gasket Kit 916/996/998 calpolo17 Superbikes 2 Aug 14th, 2008 10:09 am
Head gasket........ DukeDesmo Superbikes 24 Aug 4th, 2008 1:46 pm
Rubber gasket PhilipIsland Supersport 3 Oct 17th, 2007 3:03 pm
Oil Filter Gasket Keyboard Superbikes 8 Jun 7th, 2007 8:15 am
916 head gasket/cyl base gasket mjfrank Superbikes 15 Jun 1st, 2007 10:52 am
