VDST question - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old May 6th, 2010, 9:02 am   #1 (permalink)
VDST question
Hi all,
I'm thinking about getting a VDST software to do the basic maintenance of my Hyper.
All I want to do is the basic stuff like TPS reset, CO trim and clear error code.
I'm running a Hyper with the Termi 2-2 (and teh dedicated ECU)
After a little bit of research on the net, I found 2 versions, a VDSTS and VDSTS Pro that is 700$ more expensive.
Can anyone tell me what's the difference between both ? Does the pro one allow more setting or is it just that the pro is multi ECU ?
Any feedback on the use of this VDST is welcome !
Thanks.
Old May 6th, 2010, 9:41 am   #2 (permalink)
Raiden's Avatar
This should answer your question.
http://www.desmotimes.com/product915.htm
basically the cheap one is specific to one ecu.
2008 HM1100S
Raiden is offline   Reply With Quote
Old May 6th, 2010, 11:11 am   #3 (permalink)
I Wear The Silver Badge
BigMac038's Avatar
I have the same setup, and just did all what you seek last weekend with a friend's VDST. He has the single ECU version. Worked great!!
2008 Hypermotard 1100S - Black
2002 YZ250F
1.) Always Look Good. 2.) Know What You Are Doing. 3.) If You Don't Know What You Are Doing, See # 1.
BigMac038 is offline   Reply With Quote
Old May 6th, 2010, 9:10 pm   #4 (permalink)
PKM
If you are a DIY'er the VDST is great and highly recommended!
As already noted, the $199 version works for a single model and it will work with all DP ECU variants for that model (like with the Termi kit).
I rerouted the diagnostic plug on the bike so I could attach the VDST without removing the right fairing.
The Technoresearch website has the user manual and the software program for download if you want to read up or check out the software interface.
If you have any other specific questions let me know!
PKM is offline   Reply With Quote
Old May 6th, 2010, 9:56 pm   #5 (permalink)
sick50ford's Avatar
VDST for Hyper share
Re: Vdst MAZDuc Sport Touring 2 Mar 4th, 2010 8:17 am
Vdst RockingM Sport Touring 0 Mar 27th, 2009 7:20 pm
Question: VDST software & TPS Reset NoMAD Superbikes 3 Dec 30th, 2008 4:24 pm
my first VDST run DesmoDuke Superbikes 2 Nov 21st, 2008 9:44 am
Vdst nemesisHM HyperMotard 3 Sep 17th, 2008 10:43 pm
