Hyper License plate relocator - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Apr 30th, 2010, 5:24 pm   #1 (permalink)
HyperRyan's Avatar
Hi all. I'm new to the forum. I was wondering what options I have to relocate the license plate. I feel it hangs down to low. If I ever had a passanger it would probably come close to rubbing. Thanks in advance for the input.
HyperRyan is offline   Reply With Quote
Old Apr 30th, 2010, 8:43 pm   #2 (permalink)
Extended Member
CAlexio's Avatar
removed the big plastic plate holder, and then with just a small metal plate you can attach the license plate to the sliding bar that holds the exhaust, or anywhere else it will fit.
the license plate light can be fitted just under the tail and still work to light up the plate, just tuck the wiring neatly into the side pods.. hope these pics help. Zero $ spent.
Hyper License plate relocator-dsc_0057.jpg   Hyper License plate relocator-img00034-20100324-1845.jpg   Hyper License plate relocator-img00033-20100324-1845.jpg
Old Apr 30th, 2010, 9:34 pm   #3 (permalink)
HyperRyan's Avatar
Thanks
That should work perfectly. I appreciate the pics.
More license plate relocator options moto StreetFighter 20 May 5th, 2011 12:35 pm
Rizoma License Plate Relocator Motovation StreetFighter 0 Jul 21st, 2009 9:37 am
License Plate Relocator For 748 boostedt0y Superbikes 10 Jun 28th, 2007 10:33 pm
My attempt at a license plate relocator gcardamone Superbikes 6 Apr 24th, 2007 1:25 pm
900 SSie license plate relocator dutchduc900 Supersport 6 Feb 14th, 2006 4:07 am
