Ca Cycleworks Big Tank question - Ducati.ms - The Ultimate Ducati Forum
Old Apr 22nd, 2010, 6:30 pm   #1 (permalink)
Ducati Designs
pgeller's Avatar
Images: 27
Hi folks. I just finished up installing the 6.8G (!) tank upgrade on a friend's Hyper. Now he can wheelie to the moon without refilling, I guess. If any of you have completed this kit, can you tell me, where exactly did you locate the crankcase breather air filter (supplied with the tank kit)? I cannot seem to find a secure location within reach of the stock hose. Between the throttle bodies didn't work well (fouled the throttle mechanism).
The owner also supplied me a K&N filter (from TPO) as an alternative to the little gauze filter supplied by Ca Cycleworks, but that one, which mounts right to the breather, does not clear the shock linkage.
Thanx in advance for your wisdom.
pg
DD
pgeller is online now   Reply With Quote
Old Apr 27th, 2010, 6:20 pm   #2 (permalink)
Does this help? You can just see other small filter is under the red frame tab in front of the rear cylinder at the top of the photo
Ted
r60slash5 is offline   Reply With Quote
Any word on a larger tank? hbliam HyperMotard 778 Dec 27th, 2009 3:23 am
Seat and tank mounting help 65bayracer Vintage 7 Aug 26th, 2009 7:05 am
tank adjustment question yukio Superbikes 3 Sep 18th, 2007 2:39 pm
ANOTHER gas tank question hotflashjr Sport Touring 5 Mar 16th, 2006 4:55 pm
Gas tank question hotflashjr Sport Touring 2 Mar 14th, 2006 7:38 am
