Anyone shorten the 2-1 termi can? - Ducati.ms - The Ultimate Ducati Forum
Old Apr 19th, 2010, 9:03 am   #1 (permalink)
went and checked out the hyper im getting tomorrow this past weekend
one question about the termi 2-1 single exhaust can, anyone ever shorten the canister to bring it inside the body lines on the rear? i think it would look neater being shorter than the tail and also sound a little meaner. actually expected the bike to be louder, but maybe its a good thing it is quiet for my neihborhood. haha.
03 m916 dark
trippin green is offline   Reply With Quote
Old Apr 20th, 2010, 9:33 pm   #2 (permalink)
freezer16801's Avatar
if the bike with 2-1 termi isn't loud, check to make sure that the DB killer is removed. You can do so by looking for 4 or 5mm allen bolt isn't attached at the end of the can. Mine is quite loud without the db killer and nice and quiet with it in. Shortening the can would be very loud, I imagine.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Apr 20th, 2010, 11:11 pm   #3 (permalink)
johnchypermotard's Avatar
i tried shortening the carbon can on an extra termi 2-1 slip on i have ... the carbon can has flairs on each end where the titanium end cap and the stainless front cap are riveted to the can. checked with our local carbon fiber guru here in the bay area ... he advised it is not possible to cut and then join the shortened can ... so i gave up on the idea.
perhaps the titanium canned termi 2-1 slip on might be shortened?
Old Apr 21st, 2010, 12:41 am   #4 (permalink)
Hypermotard with Termignoni mini
http://www.youtube.com/watch?v=mhICm7lqB8I
check this out!
sst256 is offline   Reply With Quote
Old Apr 21st, 2010, 2:15 am   #5 (permalink)
Johnb250's Avatar
I shortened mine this winter, quite straight forward with the correct tools. I was worried about those slight flares too but it turned out fine. I think they are caused by heat. The end caps will fit the carbon oval tube anywhere you choose to cut. Cut the carbon with a dremel and diamond disc cutter, makes a very clean cut. The only other tricky thing, if you want to do it right, was when you shorten the bronze/brass mesh to re-silver solder it back. ( The mesh stops the rock wool blowing out )
As for sound when I took it apart the rockwool was gone/moved 3" at front and thats how much I cut off, so for me there was no change in sound.
Theres a thread somewhere on another forum with a few pics which is helpful.
So if you are used to drilling cutting moding go for it.
Johnb250 is offline   Reply With Quote
Old Apr 21st, 2010, 9:18 am   #6 (permalink)
yup, used to it. ive got the factory low mount arrow on my speed triple, i cored it, repacked it, but didnt shorten it. titanium is a bitch to cut. besides it was getting on the too loud side for my neighbors. when i checked the bike out saturday didnt see a baffle in there. i'll double check again tomorrow when it gets delivered. i'll ride it the way it is for a while, but im sure im gonna cut it since it just looks too long on the side like that.
thanks for the replies guys!!
03 m916 dark
Old Apr 21st, 2010, 9:23 am   #7 (permalink)
check this out!
that is EXACTLY what im talking about. perfect lines in the rear!!
03 m916 dark
Old Apr 21st, 2010, 11:40 am   #8 (permalink)
sweet! i will try it.
Old Apr 21st, 2010, 1:10 pm   #9 (permalink)
Johnb250's Avatar
Pic for reference, 3" cut.
Old Apr 21st, 2010, 2:38 pm   #10 (permalink)
i wonder what they cut off in the video. i think it could be a long shorter than the 3" you did.
oh and are your headers polished?
03 m916 dark
MS 1200 exhaust options- full Termi vs Termi can only fixinbones Multistrada 198 Jul 22nd, 2010 9:13 am
749 Termi help SFduc749D Superbikes 2 Jan 28th, 2010 7:09 am
Dyno shows that Termi DB killers kill more than just DB's. wasp1000 Sport Classic 23 May 27th, 2009 7:45 pm
the full termi is a DEAL at $2000 rubyvrooom HyperMotard 81 Jan 12th, 2008 12:38 pm
Advice needed 749 w/ Termi ECU? sludge Ducati Motorcycle Chat 3 Jun 8th, 2007 6:16 pm
