Motor of Death II - Ducati.ms - The Ultimate Ducati Forum
Old Apr 16th, 2010, 12:12 am   #1 (permalink)
08hyper's Avatar
Motor of Death II
Well I did my dyno run today, the new motor has about 400mi.
My Motor of Death I, which was SUPER FAST! IMHO, made 102.03 HP & 76.21 TQ, but the motor died, (crank bearings failed) the NEW & improved MOD II is now making 106.57 & 78.91 TQ (HP up 4.54 & TQ up 2.7!) same dyno, same operator, same gearing
The difference between the motors is in the bottom end, the MOD II has a lightened crank, with Carillo rods, the crankshaft assembly was balanced with the big-bore pistons, and I installed ceramic crank bearings, I would have bet that the HP & TQ gain would have been little to none, but I was WRONG! with the lighter crank weight & friction free ceramic bearings, she ponied up! even with heavier oil!
But there was a slight side effect, even though she runs like a bat out of Hell, I lost some top-end, the HP peak is now 200rpm lower, I guess the lighter rotating force of the crank takes out some of the over rev, so the power peak is lower. So I may have to "raise" the gearing by dropping a tooth or two on the rear, hows that for having more power? Aloha Alex
Old Apr 16th, 2010, 1:38 am   #2 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
You still won't go faster than a 1:52 at Fontana.
I, on the other hand, will be in the mid 1:40s at our next group outing.
-Marco
Da_Bull is offline   Reply With Quote
Old Apr 16th, 2010, 3:33 am   #3 (permalink)
Wow that's impressive!
italianpower is offline   Reply With Quote
Old Apr 16th, 2010, 8:46 am   #4 (permalink)
yabo0569's Avatar
very impressive! Does your top speed changes now with all of that power? About how much did you spent?
yabo0569 is offline   Reply With Quote
Old Apr 16th, 2010, 9:48 am   #5 (permalink)
08hyper's Avatar
HA! just looked, found the old lap time sheets, best laps 1:49, most 1:50's
and thats when Todd & I had stock motors! so there! Have fun & be safe out there! Aloha Alex
Old Apr 16th, 2010, 10:01 am   #6 (permalink)
bromike666's Avatar
Dude, Ida kept my mouth shut now you're now the new Todd. Guess you'll need to ride level three and duke it out.
"I love the sound of a dry clutch in the morning"
10 F1098S Streetfighter
08 Hypermotard 1100S
08 Multistrada 1100S
07 SM610
bromike666 is offline   Reply With Quote
Old Apr 16th, 2010, 10:11 am   #7 (permalink)
08hyper's Avatar
YES & NO, if your bike was stock and you could hit redline in 5th, and I was in 5th at redline, you would be faster, as you have about 200 more rpm on top, more rpm, more top speed, its just that I would get there much quicker, now since the stock Hyper can't hit redline in 6th (at least mine couldn't) and my MOD II can, I would pull more rpms on top & will have a higher top speed.
We did "play" a little while on the dyno, we wanted to see how fast she would go on the dyno, WFO in 6th gear! the actual ground speed (stock gearing) hit 140MPH before slamming into the rev limiter, speedo was indicating 150MPH.
I had a lot of fun on the dyno yesterday! Aloha Alex
PS: toooo much $$
Old Apr 16th, 2010, 10:29 am   #8 (permalink)
johnchypermotard's Avatar
very cool alex -
so, just a rough guesstimate that those 4 additional hp cost about $23,942.52 each ... right?
Old Apr 16th, 2010, 11:17 am   #9 (permalink)
Decreasing Dave's Avatar
Images: 14
Alex, I disagree with your assesment of your "lack of top speed".
Just because your powerband signs off 200 RPM lower than before, doesn't mean that the bike just shuts down. On the contrary, your bike still probably pulls harder than mine at those RPMs. So why would yours be slower???
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Apr 16th, 2010, 11:30 am   #10 (permalink)
oalvarez's Avatar
What would you do with all the power in a real superbike? That would be fun to watch....the answer is NO!
I'm so glad the Wrightwood tunnels remain closed
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
oalvarez is online now   Reply With Quote
suggested roads from bay area to death valley? johnchypermotard HyperMotard 4 Jan 13th, 2010 1:21 pm
Death Valley Ride report (link to pix...) DGJ Sport Classic 17 Apr 12th, 2009 3:40 pm
Road Trip to Death Valley and Zion NP demoni Ride Tales 15 Dec 11th, 2007 3:07 am
Death Valley Trip superlight93 Sport Touring 8 Aug 30th, 2007 6:13 pm
