removed turn signals, now lights don't work - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!SportbikeTrackGear
Old Apr 4th, 2010, 11:45 am   #1 (permalink)
Extended Member
CAlexio's Avatar
I removed the front turn signals on my hyper recently, and since I've been indecisive about which ones to replace with, I just left them off. Since then, it seems like my front and rear lights don't work anymore. When I pull the trigger for highbeam flash it works, and the brake light comes on when the I use the brakes. Any ideas?
Old Apr 4th, 2010, 3:46 pm   #2 (permalink)
dave2riff's Avatar
Well, since the brake light works without the lights fuse (found this out at a
track day when I got flagged-- Doh!), I'm betting the fuse got blown. Maybe
an open ended turn signal connection shorted to ground and blew the fuse?
The lights fuse is a 15 amp in the fuse box under the right side panel. You can
see the black rubber lid of the fuse box with a flashlight, just look down into
the slot on the side panel. The lid is held on the front/outside by a soft rubber latch.
You can pop the lid without taking the side panel off, but it takes some amount
of fiddling... very thin fingers or a hooked tool.
'08 Hyper "S" w/ a few tweaks
Old Apr 5th, 2010, 9:35 am   #3 (permalink)
Revelstoker's Avatar
removal
I pulled off all my turn signals and license plate light for a track day and the headlight still worked. Tail light only worked with the lever.
Any chance you unplugged the headlight when pulling the signal wires out???? Just a thought
Revelstoker is online now   Reply With Quote
Old Apr 5th, 2010, 3:06 pm   #4 (permalink)
Extended Member
CAlexio's Avatar
thanks for the ideas guys... checking when i get home
Old Oct 13th, 2010, 2:28 pm   #5 (permalink)
NoPower's Avatar
Did you ever get it figured out
2007 Monster 695
2007 CBR 600RR (track)
NoPower is offline   Reply With Quote
Old Oct 13th, 2010, 2:37 pm   #6 (permalink)
Extended Member
CAlexio's Avatar
funny enough.. I started this thread a year ago I think. Yesterday my lights went out again, I changed the 15v fuse and everything works again.. then this thread popped up after a year in the netherregions of ducati.ms
weird how things happen.
Old Oct 13th, 2010, 3:25 pm   #7 (permalink)
It's probably Ducati Miami's fault...
Old Oct 13th, 2010, 3:54 pm   #8 (permalink)
Monstaman's Avatar
Originally Posted by alexio View Post
has anybody seen my smoke?
You probably need to buy more smoke to put back in the wires and unplugging them has clearly let it all out
... runs for cover with flame suit on ....
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Oct 13th, 2010, 7:02 pm   #9 (permalink)
Gilly's Avatar
Images: 17
You most probably doucheboxed the fuse, smell it. If it smells like tuna. It's douchedboxed.
"Oh My!" thread link... FFS!
Old Oct 13th, 2010, 8:37 pm   #10 (permalink)
doon's Avatar
Seems like you and Monstaman should stay away from electricary
doon is offline   Reply With Quote
Aftermarket Turn Signals soupgfx Monster 1 Feb 2nd, 2010 5:31 pm
Problem with Turn Signals QTip StreetFighter 13 Oct 31st, 2009 6:18 am
Which front turn signals for 748/916/996/998??? alon Superbikes 5 Jan 8th, 2009 3:40 pm
Help!! 748 Turn Signals! BaconAndScotch Superbikes 4 Jun 11th, 2008 5:07 pm
Help!! Weak turn signals in tail vmuth Superbikes 2 Mar 22nd, 2006 3:02 pm
