Apr 3rd, 2010, 10:49 pm
#11 (permalink)
Yeah I finally bought a Mity Vac pump when I swapped out my rezzies on the Hyper. It works, but I think it is easier to do it old school. I like to use a clear jar so I can see the fluid and make sure the tube off the bleeder is submerged.
Out!
2008 Ducati Hypermotard
Apr 4th, 2010, 3:25 pm
#12 (permalink)
I use the clear jar method too, with a Motion Pro one-way bleeder line. This is a foot
of clear tubing with an anti-reversion valve in the middle of it. Not essential, but
helps a little with the bleeding process.
Also, if you are new to handling brake fluid, it can be nasty stuff and remove paint
if left on the finish for a while. Best to cover all those expensive painted panels
with towels while working with brake fluid, especially since the fluid reservoirs on
the handlebars are _right over_ the side panels.
'08 Hyper "S" w/ a few tweaks
Apr 4th, 2010, 5:50 pm
#13 (permalink)
Originally Posted by kingsnake1650
if beer isnt involved... you arent working on it right!
beer? takillya is better
Motorcycles: Ducati Hypermotard 1100 (SOLD), Ducati MH900evoluzione (SOLD), Multistrada 1200 S Touring
Apr 4th, 2010, 8:29 pm
#14 (permalink)
I save that for major engine work...not the light stuff
Apr 4th, 2010, 9:48 pm
#15 (permalink)
dude ... ANY work should require takillya
Apr 4th, 2010, 11:26 pm
#16 (permalink)
I think the vacuum gun works great but you do need to have tight hoses over the nipples and also put a bit of grease over the threads on the nipple because that is where the air comes in once you crack the bleed screw. Once you have the air tight seal the vacuum gun works super fast... you just have to watch the fluid level in the reservoir
Apr 5th, 2010, 1:31 am
#17 (permalink)
grease, hoses, nipples, vacuum, seals, screw ... what the heck are you doing?
sounds a little kinky
Apr 5th, 2010, 11:34 pm
#18 (permalink)
I got a new takillya drink for you. Get some XO Cafe' Patron (coffee/choclate taste) pour 3/4 full in a shot glass and top it with some Bailey's poured in over the backside of a spoon............slam it.................mmmm, mmmm, good!
Get a few of those in you and you can bleed the rear correctly too.
Let's do it for Johnny man!
Out!
Apr 6th, 2010, 12:32 am
#19 (permalink)
....its also good for extracting urine from cats (thats pretty hard to do) , milking my dog, and obtaining stem cells from embryonic mice...
Apr 6th, 2010, 12:00 pm
#20 (permalink)
Out!
kind of a mexican/irish car bomb? sounds good.
