Exhaust Leak - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!SportbikeTrackGear
Old Apr 2nd, 2010, 10:39 am   #1 (permalink)
DMSTAINLESS's Avatar
Exhaust Leak
Hey guys,
I was just wondering about some water that comes from my exhaust when i let my bike warm up. Im not concerned about the water but where its coming from. Its coming from bout back side of flapper valve. I also feel air movement there. Im getting redy to install my cat delete, so i will check all connections, just wondering if this is common? Surely it not spose to leak like that?
thx
$TAINLE$$
DMSTAINLESS is offline   Reply With Quote
Old Apr 2nd, 2010, 11:07 am   #2 (permalink)
Caidly's Avatar
Condensation. Normal and should burn off (evaporate) after a few miles.
if you need to know... ask...
Old Apr 2nd, 2010, 3:18 pm   #3 (permalink)
AXE
AXE's Avatar
The exhaust fittings aren't a perfect match and they tend to seal up when they warm up and exapand some. My Zard does the same thing and they have a pretty good clamp on that connection.
If you loosen all the connections and adjust the alignment of the pipes prior to tighten the clamps you will get a more positive seal. Now would be a good time to check since your pulling things apart anyway.
Out!
2008 Ducati Hypermotard
Old Apr 4th, 2010, 9:27 pm   #4 (permalink)
Images: 4
I replaced the larger clamping fasteners with grade8 steel and used antiseeze unlike the dry factory assembly of the stainless fasteners.
I wasn't able to get the oem bolts tight enough to take care of the wiggles even with anti seeze.
berndt is offline   Reply With Quote
Old Apr 5th, 2010, 11:09 am   #5 (permalink)
Mati-O's Avatar
I just brought my bike out of storage and took off the Termi 2-1, looking for sleeping mice. I saw some orange silicone around the egdges. does this need to be replaced? there wasnt much on it to begin with.
08 Hypermotard 2-1 termi, DP race seat, CC pressure Plate, Speedy Moto flow clutch cover. Rizoma Logic mirrors/ turn signals.
06 749 Biposto- Traded for above. I'll miss u bit#ch.
Mati-O is offline   Reply With Quote
Two Brothers Racing Ducati Carbon Exhaust Blowout johnw McCoy Motorsports 1 Feb 13th, 2010 11:38 pm
Oil leak x 3 IlMostroNero Monster 1 Jan 26th, 2009 10:55 pm
Exhaust?? ECU?? GHEZZI HyperMotard 24 Jan 6th, 2008 12:34 pm
749R exhaust (WARNING! long question) CAlexio Superbikes 9 Dec 21st, 2007 8:07 am
How loud is your exhaust? SouthsideDuc Superbikes 16 May 19th, 2006 12:07 am
