When you turn it off, are you turning the key all the way over to the left - into the "P"ARK position? I think its one click past lock. If so, it will turn on the park lights.
your front or rear brake switch may be stuck if you mean that the brake light is still on when you dismount from the bike and it is still running. check that out.
just a little unclear what your problem actually is...
