Termi 2-1 and oil screen change - Ducati.ms - The Ultimate Ducati Forum
Old Mar 24th, 2010, 6:03 am   #1 (permalink)
I'm thinking of doing an oil change at half time instead of waiting for the 7,500 one. I've had a look through the manual and some posts on here and am curious as to whether or not I have to undo any more thant the manifold clamp to clear the oil screen access. Will it drop down far enough or do I need to loosen another clamp to rotate it away?
I've done plenty of other oil changes on other machinery, just wanted an idea of how much time to allocate, thanks.
2008 Ducati Hypermotard, 1970 Suzuki TC 120 sold
2005 KTM Supermoto sold, 1972 Suzuki TS250 sold
2002 KTM Supermoto sold, 1972 BSA 500 sold
1968 Ducati 350MKIII Desmo, 1978 Suzuki GS550 sold
1979 Honda XL500 stolen
remery is offline   Reply With Quote
Old Mar 24th, 2010, 10:32 am   #2 (permalink)
08hyper's Avatar
30min tops (or less)
As long as you have a "straight in" acess, thats all you'll need. So whatever it takes.
No one here should wait till the 7500mi mark to do a oil change, like you, they should do it much eariler, I change mine at every 2500mi (easy 4 me 2 remember) Aloha Alex
Old Mar 24th, 2010, 3:47 pm   #3 (permalink)
johnchypermotard's Avatar
to service the pre-filter, you need to drop the horizontal header. pretty straightforward operation ... a few nuts and bolts and springs.
Old Mar 25th, 2010, 12:06 am   #4 (permalink)
Thanks for that, I'd better get my arse into gear then.
The Case for Using Mobil 1 15W-50 Automobile Oil in a Motorcycle Shazaam Hall of Wisdom 17 Jan 10th, 2012 2:35 pm
Metal Particles on Oil Screen Shazaam Hall of Wisdom 4 Jun 4th, 2010 8:27 am
848 oil change tweek Superbikes 22 Feb 12th, 2010 12:47 pm
Hyper Oil Change josephvman HyperMotard 4 Jun 7th, 2009 7:14 pm
Motorcycle Oil used JohnE1000 Ducati Motorcycle Chat 24 Apr 19th, 2009 1:50 pm
