Mar 19th, 2010, 11:20 pm
Battery Bracket question
Ok i am stumped. When i took the battery out last year i didnt note how the braket fit snug,
so here i am getting my prep done and i cant for the life of me figure it out, the bracket just shakes around....
I may just be retarded, which is fine i guess, but since this was an issue found in 08 its nowhere to be found in the manual...
help would be mucho gracias!
Keith
Bikes
2008 HYM1100
2010 F800GS
sometimes life makes sense, other times it doesn't, but its always worth it.
Mar 20th, 2010, 1:27 am
I'm a little confused by what you mean that it shakes around. Have you tightened the nut that clamps it to the panel bolt? On mine, it doesn't hold the battery super snug, but it doesn't shake around at all.
Mar 20th, 2010, 1:29 am
Keith
The bracket side panel bolt is a long one, put it in first, tighten down, from the bottom install the thick washers & bracket, in the right location, and tighten the nut on the bottom side while holding the top of the bolt so it will not turn, hope this helps, Aloha Alex
Mar 20th, 2010, 6:31 am
Yeah it is a litle tricky ...get a good look at it and it should come to you...
A search should help .
While you are at it ...
What I done is Pack some thin sill plate gasket material (styrofoam type 1/4 inch thick) around the battery to make it unlikely that stones would lodge between the battery and Gas tank and causing a leak..
Simple fix..to what could be a big problem...
2011 Red Multistrada Touring
Mar 20th, 2010, 6:37 am
As soon as I can find the digital camera I'll take a picture. Sometimes a picture is worth....
Mar 20th, 2010, 9:10 am
From the top : put plastic washer on top of CF (or plastic)
run long bolt 1/2 way down (4mm allen wrench)
Put fat washer up on underside of frame bracket against the welded on nut of the frame bracket then battery bracket then the flanged nut run part way up
snug top bolt (4mm)to secure CF (or plastic)
WHILE Backing up the 4mm bolt run the bottom nut to secure the battery bracket , against the fat washer, against the frame nut that is welded on the frame bracket
Tighten securely ...
Now you remember don`t you
I only had 2 washers a clear plastic one and a fat one
Mar 21st, 2010, 6:02 pm
I had to custom fit mine too,poor setup by ducati.
Mar 21st, 2010, 6:58 pm
Yes now i do remember
last night after i read this at about 1am i went back out and not even a minute later it was on and tight...
sahweett
then went riding today...
Bikes
2008 HYM1100
2010 F800GS
