Need different ECU for Cat delete? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comMotorcycle.com Classifieds!SportbikeTrackGear
Motorcycle.com
Old Mar 18th, 2010, 2:34 pm   #1 (permalink)
Frustration's Avatar
I have the race ECU that came with the Termi and Airbox set but am thinking about the Cat Delete.
Is there a separate ECU for that??
would it come with the DP cat delete?
Frustration is offline   Reply With Quote
Old Mar 18th, 2010, 2:48 pm   #2 (permalink)
Caidly's Avatar
You're fine.
if you need to know... ask...
Old Mar 18th, 2010, 3:39 pm   #3 (permalink)
kedo's Avatar
You do not need to do anything but install it and enjoy the weight-loss, sound and performance improvements. Cheers!
kedo is offline   Reply With Quote
Old Mar 18th, 2010, 6:24 pm   #4 (permalink)
NICE!
Thanks.
Am I right thinking I can fit this up by just removing the lower header?
Old Mar 18th, 2010, 10:51 pm   #5 (permalink)
bullet3z's Avatar
It might take a little more than that. When I put my LV slip on's on the bike I also added the cat eliminator at the same time. It was kind of a pain in the but to get everything to line up. I did loosen the front facing header to get it all to work together.
bullet3z is offline   Reply With Quote
Old Mar 19th, 2010, 12:17 am   #6 (permalink)
I'm having the DP cat elim pipe put on now during the 12k service. I have the termi slips / ecu / airbox lid as well.
still thinking about doing the PC because I'm convinced my air/fuel isn't optimal because of the climate conditions here.
Cog
2008 Hypermotard 1100S
Singapore (via Texas)
Cogito Ergo Zoom is offline   Reply With Quote
Stock ECU vs. Ducati Performance ECU jones525 StreetFighter 25 Feb 26th, 2011 10:02 am
St3/4 Dp Ecu macraige Sport Touring 25 Apr 3rd, 2009 8:56 pm
Ducati ECU remap kit moto Motowheels 0 Feb 17th, 2009 12:32 pm
Dyno results with bad ecu and slipons uzirider HyperMotard 4 Sep 19th, 2008 9:37 am
15M ecu - help! dirkwrong Ducati Motorcycle Chat 7 Mar 28th, 2008 7:46 am
