o2 sensor plug after removal - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.comMotorcycle.com Classifieds!
Old Mar 13th, 2010, 7:46 am   #1 (permalink)
Sorry if this is a re-post. I removed the o2 sensor after installing the LV cat eliminator pipe and now I'm wandering what to do with the plug that comes from the ecu. Zip tie to frame? Remove from ECU? Any suggestions would be great! Thanks!
Shaun
xrmoneypit is offline   Reply With Quote
Old Mar 13th, 2010, 10:14 am   #2 (permalink)
sinex's Avatar
Are you using the standard pipes and ECU, I guess you are? as the O2 plug is normally removed as part of the termi 2-1-2 set up, if using the LV de-cat with a standard set up, the o2 plug should be retained
sinex is offline   Reply With Quote
Old Mar 18th, 2010, 5:43 pm   #3 (permalink)
yeah, I removed the plug from the cat when I installed the Leo Cat eliminator. now I just have the connector that comes from the ecu hanging near the frame on the right side. Re-flashed ecu on the way back from Silverback Performance.
Old Mar 18th, 2010, 5:58 pm   #4 (permalink)
What does Silverback charge for a flash based on stock pipes and the cat eliminator? Are you doing an airpox mod also?
'08 HyperMotard
'05 ST3
'77 RD 400
CraigC is offline   Reply With Quote
Old Mar 18th, 2010, 10:54 pm   #5 (permalink)
bullet3z's Avatar
Do you mean the flapper valve? My o2 sensor went in the LV cat eliminator bungle the same way it came out of the factory cat bungle. The flapper valve was a different story. If so here is a pretty good thread about the valve.
exhaust flapper valve removal ...
bullet3z is offline   Reply With Quote
Old Mar 19th, 2010, 9:35 pm   #6 (permalink)
All Leo Vince Owners without O2
Silverback charged $300 for a reflash. I was unable to trailer the bike to Wisconsin, so I hope that the mapping is close. Have to pick up the ecu tomorrow. Fred was very professional to deal with though. I did the airbox mod with K&N. Right now, I have the Cat eliminator pipe with plug that fills the O2 spot. What should I do with the opposite end of wiring??
Shaun
Old Mar 21st, 2010, 6:07 pm   #7 (permalink)
I ziptied mine to the frame.
motodan is offline   Reply With Quote
Old Mar 24th, 2010, 7:11 pm   #8 (permalink)
Thanks
999 Airbox removal ZDM Superbikes 21 Apr 17th, 2010 10:01 pm
996 swingarm removal? engine removal? m90daytona Superbikes 2 Mar 16th, 2009 5:27 pm
Key (ignition removal) removal Miykl Superbikes 3 Apr 25th, 2007 11:20 am
Alternator cover removal questions - 749 (03) ducati_atx Superbikes 4 Oct 7th, 2006 9:03 am
999 Fuel Tank Removal Help Please? kabinski Superbikes 4 Feb 12th, 2006 11:26 am
