Fuel Pump drip - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.comMotorcycle.com Classifieds!
Old Mar 10th, 2010, 1:32 pm   #1 (permalink)
Activator's Avatar
Fuel Pump drip
Hey all- I'm sure this is normal, but just wanted to check.
My Hyper has been in winter mode (ie: sitting in the garage) for a few months. Too much snow/ice and salt to take 'er out. During the last few weekends we had some nice days, so I've been taking 'er out for short rides. It takes quite a few cranks to fire up. (My '08 has a one-button starter. You give it one push, and the solenoid takes over until the bike starts.) Once running, everything seems fine, but I've noticed that there is some gas dripping from the fuel pump cover under the seat. The drip stops once the bike is running, but it's still disconcerting to have gas dripping out under the bike and onto the swingarm.
Should I forget about it? This has only happened the last 2-3 times I've started it, after being stored for awhile and with 8-10 cranks before firing up.
Thanks!
2008 Hypermotard 1100 - Red (sold)
2006 Mutistrada 620 - Gloss Black (sold)
2004 BMW R1100S - Grey (sold)
2000 Aprilia Pegaso - Blue (sold)
Activator is offline   Reply With Quote
Old Mar 10th, 2010, 2:00 pm   #2 (permalink)
Sounds like it may be an o-ring may have failed from one of the fuel lines. If its under warranty take it in and see if they will take care of it for you. If not then take it apart yourself and see if either fuel line has a damaged o-ring. Also check the bolts that hold the sending unit to the tank. Ensure that those are all nice and tight; don't over torque those!
I'm not sure if you can purchase the o-rings separately from the fuel lines but I don't see why you shouldn't be able to.
originalebm is offline   Reply With Quote
Fuel pump / starting problem hintonrsvr Supersport 6 Jan 30th, 2010 8:17 am
Superbike owners, help me out with a fuel tank (pump) question!? mpaschetto Superbikes 3 Jan 12th, 2010 6:05 am
900ss fuel pump Kiwirider Supersport 19 Jan 3rd, 2010 3:13 pm
fuel pump? RockingM Sport Touring 8 Mar 15th, 2009 9:53 am
916 Fuel Pump - no power? johnnySV Superbikes 2 Jan 18th, 2009 12:49 pm
