Back Brake Not Working After Changing Pads - Ducati.ms - The Ultimate Ducati Forum
Old Mar 7th, 2010, 8:30 am   #1 (permalink)
hello,
So, it was time to change the back brakes. Pads are changed, but back brakes do not work. I hit back brakes plenty of times to build pressure and nothing the brakes will not apply the pressure to close them on the rotor. Please help, as this seems very weird to me. What could be the problem ? Will I have to bleed the brakes over this ? If so, how hard of a task is this as the whole "getting air in your brakes lines" kind of worry me but this is something i should be able to do.
Ferrell75002 is offline   Reply With Quote
Old Mar 7th, 2010, 12:16 pm   #2 (permalink)
minusone's Avatar
Change your mechanic.
Mate.... if you have trouble doing this simple procedure, then on safety terms alone you should not be working on the bike.
It is unlikely to require bleeding if all was ok before unless you have opened the lines.
Check nyour re assembly process.
Old Mar 7th, 2010, 12:42 pm   #3 (permalink)
08hyper's Avatar
Double check your reassembly, pads in the right way, pins OK, and if your sure its all good, then all you can do is to bleed them, pretty easy to do, just do a tread search, brakes are important maintenance items, if your not sure what your doing, I would go to a pro. (cheap insurance) Aloha Alex
Old Mar 7th, 2010, 1:14 pm   #4 (permalink)
MTScott2's Avatar
Images: 5
I think I remember reading that the rear are or can be a little tricky to bleed , due to the caliper being lower and the line routing...
2011 Red Multistrada Touring
Old Mar 7th, 2010, 5:57 pm   #5 (permalink)
Ric
Ric's Avatar
Get the caliper up higher than the master (i use my B&D workmate beside the bike),put a block of wood in between the pads,and bleed it slowly to allow the air to rise to the top.My ss was a pain in the butt the same way.
2001 Goldwing 1800
2009 Hyper 1100S
Ric is offline   Reply With Quote
Old Mar 8th, 2010, 2:31 pm   #6 (permalink)
AXE
AXE's Avatar
Nobody's back brake works correctly as they are not bled properly from the factory. The only way to bleed them is to remove the caliper and raise it above the master cylinder and bleed it from that position. I have a thread posted on the subject, once they are bled right they work pretty good.
Out!
2008 Ducati Hypermotard
Old Mar 11th, 2010, 12:47 am   #7 (permalink)
Out!
wonder why its not set-up correctly from the factory
Bourgoine82 is offline   Reply With Quote
Old Mar 11th, 2010, 1:54 am   #8 (permalink)
cs363's Avatar
Images: 2
All good advice on the bleeding methods.......however, if the brake was working fine before the pad replacement, I think you should be looking at retracing your assembly steps.
At a guess I would say you've got the piston side pad skewed in the caliper or something similar which is preventing the brake operating. If this is the case, check the pad very carefully when you remove it as trying to apply the brake as you have done may have bent the pad or possibly damaged the caliper.
Let's hope not...
2005 Ducati SS1000DS Senna Gray
DP Carbon Exhaust*DP Air Filter Kit*MRA Dark Screen*ASV F3 Levers*Kaemna Seat Cowl*Tail Tidy*Hinson Slipper Clutch*Wave Discs*Modified Ohlins Shock*Race Tech Kitted Forks*Smoke LED Tail Light*Clear Indicators*Carbon for Africa!*Rizoma/STM/Oberon Red Anodised Bling Parts
1980 Honda CBX1000A Black
Kerker 6 into 2 system*Ohlins Piggybacks*Race Tech Kitted Forks*Telefix Fork Brace*Dyna Coils
cs363 is offline   Reply With Quote
Old Mar 11th, 2010, 10:48 am   #9 (permalink)
archimedio's Avatar
I think the real question here is, why are you even trying to use your rear brake?
Haven't touched a rear brake on any of my bikes in decades.
archimedio is online now   Reply With Quote
Old Mar 11th, 2010, 1:28 pm   #10 (permalink)
Moderator
stryder's Avatar
Probably a good idea to have a working rear brake on a wheelie happy Hyper, yes?
Regards,
Frank, '05 ST3, (Red!!)
"Veni, Vidi,....Ducati!!"
real quick brake pad changing question elliottw Superbikes 19 Apr 9th, 2009 5:21 am
brake tech axis rotors ... johnchypermotard HyperMotard 7 Jul 2nd, 2008 8:47 pm
Iron Brake Rotors Shazaam Hall of Wisdom 2 Dec 22nd, 2007 9:08 am
Brake Light Not Working Cagiva Elephant mysuv Ducati Motorcycle Chat 5 Jun 12th, 2007 7:26 am
Sintered brake pads 97DesmoSP Supersport 7 Sep 13th, 2006 9:57 am
