Is this normal? (Oil Leak) - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Motorcycle.com Classifieds!
Old Mar 1st, 2010, 5:59 pm   #1 (permalink)
merovingian's Avatar
So just giving my bike the once over today (2000km on the odo) and noticed quite a bit of gunk on the clutch cover and followed it down to the the oil line.
http://i532.photobucket.com/albums/e...2/IMG_1887.jpg
It doesn't appear to be oil though, it wipes off like brake dust
Any ideas?
merovingian is online now   Reply With Quote
Old Mar 1st, 2010, 7:12 pm   #2 (permalink)
elliott5's Avatar
Mine does exactly the same thing.
It looks like a build up of road gunk, probably channelled there by the barrel fins and as it is a forward facing surface it tends to stick.
I've not worried about this and have had no trouble in 6000km.
Good as gold, mate!
P.S. Clean it off on a regular basis!
2008 Hyper S
2007 FZ1N
2007 ZX6R (Track)
2004 CBR1000RR
1998 TRX 850
elliott5 is offline   Reply With Quote
Old Mar 2nd, 2010, 6:34 pm   #3 (permalink)
AXE
AXE's Avatar
It may be from the bolts on the case cover. Pull them one at a time and add a little RVT gasket maker in the hole and on the thread and retorque them. I had it on the opposite side and that is what was causing the residue. Otherwise, retorque the oil line fittings.
Out!
2008 Ducati Hypermotard
Old Mar 3rd, 2010, 12:06 am   #4 (permalink)
Monstaman's Avatar
NO oil leak is normal, check your oil cooler line couplings and tighten if needed, there are two small o rings in the oil lines coupler, it is possible that Luigi nicked these on the way in or he didn't tighten the bango to the block couplers.
Check also the casing bolts.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Mar 3rd, 2010, 12:16 am   #5 (permalink)
elliott5's Avatar
Good as gold, mate!
Mine's NEVER BEEN an oil leak!!
Just dusty residue.
2008 Hyper S
2007 FZ1N
2007 ZX6R (Track)
2004 CBR1000RR
1998 TRX 850
Old Mar 4th, 2010, 3:58 pm   #6 (permalink)
i spent nearly a whole day cleaning my eng casing for sale of the bike. i ad the same and managed to easily nip up the 2 oil line bolts 1/4 of a turn. also found my stand bolt half way out! I think it was oil vapor coming out of somewhere as it was different to the rest of the shit over the engine. btw, that bike is too clean!
Old Mar 5th, 2010, 7:08 am   #7 (permalink)
Tony and Patricio made mine so it has no oil leaks
07 hyper S, 2-1 termi - febur subframe - kyle throttle - Maxton fork conversion - nichols flywheel
Karlr is offline   Reply With Quote
Old Mar 5th, 2010, 9:04 am   #8 (permalink)
shat's Avatar
Wink
In actual fact, Gina and Maria probably assembled all of our twin sparks.
shat is offline   Reply With Quote
Old Mar 5th, 2010, 9:18 am   #9 (permalink)
Decreasing Dave's Avatar
Images: 14
Ahhhhh.......Gina.....
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Mar 5th, 2010, 12:20 pm   #10 (permalink)
True but Not Sophia?
Oil Leak - From Filter Area jbernard HyperMotard 6 Oct 8th, 2009 4:39 pm
Oil in the Airbox... cant think of what to do next... pegaxs Superbikes 6 Sep 27th, 2009 10:37 pm
Darn I got oil leak.. opinion needed... Mity2 Superbikes 11 Apr 11th, 2009 7:39 pm
Oil leak x 3 IlMostroNero Monster 1 Jan 26th, 2009 10:55 pm
St4s Oil supply leak in the middle of a ride ridelaleonessarossa Sport Touring 20 Nov 5th, 2008 9:46 am
