Feb 25th, 2010, 11:34 pm
How Can I get 100 hp from the hyper?
I will love to have 100 hp and crazy torque numbers at the wheel. What would you recomend? I will like to do it in the most economical and reliable way. I know I need full exhuast, racing cams, hyperstacks, nemesis. What else do you recomend?
Feb 25th, 2010, 11:45 pm
Big bore HC piston kit (1123cc) from Ducshop, a good port job with larger intake valves, ceramic coated piston domes & combustion chambers, friction fighting piston skirt coatings, lighter flywheel, dyno tune, should put you in the 102HP to 106HP range, but at this point its not cheap.  Aloha Alex
Feb 26th, 2010, 12:13 am
Just get a 1098,stock.....
Feb 26th, 2010, 12:21 am
Haha, whats the "fun" in that?  toooo easy!  Aloha Alex
Feb 26th, 2010, 12:28 am
how much is that? Is it reliable?
Feb 26th, 2010, 2:17 am
Extended Member
start with removing airbox, install velocity stack
$2500-your choice of open/racing exhaust w/ related ECU
$500-nemesis or pcIII mapped
$3000-big bore kit 1123cc w/ DP cams, and headwork.
$1500-labor
___________________
$7500 more or less.
this is only an approximation of pricing... should get you in the 100hp ballpark.
Feb 26th, 2010, 4:21 am
All you need is hi-comps (no need for big bore) , proper head work (stock valves are fine) , degree cams and custom map. You would get 100hp but for more torque more cc's are needed
Feb 26th, 2010, 7:05 am
Performance Center
+1 the 1122 (100mm) only adds extra bottom end and torque which is what you feel. So yes, since a Hyper is already 98mm for about 100HP you can (with stacks) just drop in HC Pistals and either add cams or do the head work for about the same money. I would say since the heads are off anyway while adding pistons is the time to do the porting with larger valves, then later you can easily add cams. If you have a DP ecu you can add a PCIIIusb or go with the Microtec which is much more tunable.
Feb 26th, 2010, 3:49 pm
Blingification
Come on guys, your not trying hard enough.
Here is what we all really need. Just start at the top and add to the cart.
Before checkout, sell first born and find a place to hide from the wife.
http://www.desmoworks.com/index.php?...ex&cPath=5_416
Feb 27th, 2010, 9:45 pm
Who do you recommend for the porting and larger valves for someone who has done most of the other stuff?
