Front Wheel Mis-alignment - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Feb 14th, 2010, 2:30 pm   #1 (permalink)
Site Sponsor
ducatimike's Avatar
I removed the wheels to replace the tires and upon re-assembly I ran into a problem. The tire was put on the proper direction on the front wheel. When I installed the wheel the discs are not lined up with the caliper. The discs sit about 1/2 inch to the right of centerline. If I reverse the wheel direction, eveything lines up. Apparently, the wheel was first assembled at the factory the wrong direction. The bearings were not pressed in properly to obtain the proper spacing of the discs. The original tire must have been put on the reverse direction, although I never checked this. Any one seen this on their Hyper? I have an 08 "S". The fix is to remount the tire but reverse the direction and assemble the wheel going the opposite direction. It must have been this way from the start, but I have never experienced this before.
Mike
99 ST4
05 Honda 450F
01 YZ 250
92 CR 500
www.emsduc.com
www.ducati-owners-group.com
ducatimike is offline   Reply With Quote
Old Feb 14th, 2010, 2:36 pm   #2 (permalink)
MarksFriggin's Avatar
Are you sure the spacers aren't just reversed?
Old Feb 14th, 2010, 2:43 pm   #3 (permalink)
did you take the spacer out the rim when you took it to the shop. they probably dropped it and now your all out of whack
Old Feb 14th, 2010, 3:46 pm   #4 (permalink)
Site Sponsor
ducatimike's Avatar
There is only one spacer on my bike on the left side. If I put the wheel in the wrong direction, the spacer sits partially inside the boot, which is the way it was when I disassembled the wheel for the first time, and everything lines up. Could someone look at their hyper and see if your spacer is on the left side and does it sit partially inside the boot around the bearing? Also check to see if your wheel rotation is in the proper direction.
thanks
Mike
99 ST4
05 Honda 450F
01 YZ 250
92 CR 500
www.emsduc.com
Old Feb 14th, 2010, 4:21 pm   #5 (permalink)
Gez
Gez's Avatar
thanks
Mike
Mines as you describe above. Spacer on the left and wheel rotation direction correct.
Gez is offline   Reply With Quote
Old Feb 14th, 2010, 6:27 pm   #6 (permalink)
Site Sponsor
ducatimike's Avatar
Hi Gez,
Does the spacer sit partially inside the boot?
Mike
99 ST4
05 Honda 450F
01 YZ 250
92 CR 500
www.emsduc.com
Old Feb 15th, 2010, 10:18 am   #7 (permalink)
hyperdookie's Avatar
Images: 9
Seated on the bike, the left spacer is long and goes past the dust seal to seat on the bearing.On the right, there is a short spacer that sits inside the dust seal and barley sticks out.The arrows on the wheel stickers point in the direction of rotation and the valve stem points to the right side.Hope this helps.
Front Wheel Mis-alignment-img_0317.jpg   Front Wheel Mis-alignment-img_0318.jpg
Old Feb 15th, 2010, 11:20 am   #8 (permalink)
There should be two spacers:
Old Feb 15th, 2010, 12:57 pm   #9 (permalink)
Site Sponsor
ducatimike's Avatar
Here is what happened. I took the wheel to a Yamaha dealer with the small spacer in place. It is captured in the boot. I left the larger spacer at home. After installing the tire the mechanic installed the spacer on the wrong side. I didnt realize it even had a spacer on the right side, I thought what I was seeing was the bearing so I didnt think of pulling it out and switching sides. I simply switched the spacers and all is well. So thanks to all for your input, especially the diagram showing the two spacers.
Mike
99 ST4
05 Honda 450F
01 YZ 250
92 CR 500
www.emsduc.com
Old Feb 15th, 2010, 3:58 pm   #10 (permalink)
ahh. a classic case of rtfm..
Suspension cheat sheet or best literature to bring to track with me? Dana Superbikes 5 Oct 13th, 2010 6:45 pm
Restricted front Wheel 749 rapter Superbikes 9 Jan 17th, 2010 12:52 am
998 front wheel on 999 BrianG Superbikes 1 Oct 14th, 2009 12:45 am
Carbon Fiber wheels for Ducati Stuboy99 Superbikes 126 Aug 27th, 2007 2:05 am
