remove front tyre - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Feb 10th, 2010, 7:14 am   #1 (permalink)
remove front tyre
This might be a stupid question but befor i remove my front tyre do i need
the, Ducati front axle alignment tool to do the front tyre back up or is there another way to tighten the nut up with out that tool..
cheers
MADWOG
MADWOG is offline   Reply With Quote
Old Feb 10th, 2010, 7:45 am   #2 (permalink)
sick50ford's Avatar
the tool helps to make things easier but it's not a necessity
I don't use one
Old Feb 10th, 2010, 7:49 am   #3 (permalink)
Varmitcong's Avatar
Follow this advice: Wheel Removal & Installation
Everything in that post works. You will not need the tool. The tool just aligns the holes. The best thing to get is a set that contains the alignment tool plus a drift. I bought mine on flea bay from Prototype Engineering (I think) and it works great. I don't believe they have any listed now, but the drift is the most helpful.
CHEEKRASHSUCKS!
Varmitcong is offline   Reply With Quote
Old Feb 10th, 2010, 7:50 am   #4 (permalink)
I don't use one
OK thanks for that sick50 that helps me out alot now i don't have to wait for it and just go ahead and put my new tyres on.
thanks..
madwog
Old Feb 10th, 2010, 7:56 am   #5 (permalink)
Ok thanks for that advice i will follow that
Old Feb 10th, 2010, 8:00 am   #6 (permalink)
hyperdookie's Avatar
Images: 9
Thumbs up
Fork pinch bolt torque values
8mm steel rod through the bottom of the right fork leg.
Suspension cheat sheet or best literature to bring to track with me? Dana Superbikes 5 Oct 13th, 2010 6:45 pm
Torque specification needed Dr.D Monster 8 Sep 24th, 2009 9:51 pm
front brakes locked up wacko-ocker Supersport 2 Jul 26th, 2009 8:43 pm
Tyre: how's this for bright? Maximus-Speedicus Ducati Motorcycle Chat 17 Feb 26th, 2007 7:45 am
Front Brakes: how hard/tight should the brake handle be when squeezed? maxvega Sport Touring 3 Aug 2nd, 2006 1:32 pm
