Feb 9th, 2010, 4:45 am
Ducati Performance Steering Damper Setting
Hey guys,
After experiencing some fairly significant headshake when I was trying to pull top speed on the bike last weekend, I decided I needed to pay a little more attention to the damper setting this week. Not having messed with it since I got the bike, of course it was on its softest setting.
I counted 25 or 26 clicks full stiff to full soft. I know that too stiff of a damper setting on some bikes will cause them to shake like hell in certain situations. Not being an expert in these matters, would be curious to hear from you guys on what you think a good place to start would be in terms of a setting.
Cheers,
Cog
Cog
2008 Hypermotard 1100S
Singapore (via Texas)
Feb 9th, 2010, 7:08 am
Cog, just curious are you running the stock suspension on your "S" with a steering dampener?
Feb 9th, 2010, 7:47 am
Yes, that's right. Unfortunately, I'm still on the stock Mar"shocking" fork.
Cog
Feb 9th, 2010, 5:33 pm
I run 6-8 clicks from full soft. More than that feels weird in low speed turns to me.
08 Hypermotard S: DP 2-1 exhaust, DP cams, DP ECU, DP Slipper clutch, DP and Shift Tech carbon goodies, Pazzo levers
01 Aprilia RS250, 85 Yamaha RZ350, 77 Yamaha RD400E, 02 Aprilia RS50 around town terror, Aprilia SR50 scooter pit bike
Feb 9th, 2010, 5:41 pm
I was running 8 clicks out from soft but after I installed the BST wheels I took it up to 10. The wheels made the bike seem a bit twitchy during high speed turn-ins and prior any higher setting the bike seemed off. Overall the new wheels just made the bike turn much faster. Just a tiny pressure on the bars and the bike flops over. Not really sure what any stiffer settings are used for as too much stiffer and the bike handles like poo.
Feb 9th, 2010, 7:45 pm
 I, and I'm sure others who view this site, would appreciate it if you took your potty mouth elsewhere.
Feb 9th, 2010, 11:48 pm
Thanks for the advice, guys....I just set it about midway at about 12 before I took off on my evening ride last night, and yes, I didn't like the feeling at all. Just felt weird.
I'm going to back it down to 6 or 7 and work up or down from there.
Cog
Feb 10th, 2010, 5:25 am
damper
Mate, No matter what you do with the crappy DP damper - your still going to find your front shakes like an 86 year old grandma's legs after a run to the toilet.
Adjust the reload on the front shocks - dont pull on the handle as you go above 90 / 100 sit closer to the front and some of the shake may be reduced.
try the GPR / Ohlins dampers.
DP make the worst dampers.
