Install of Rizoma Rearsets - Ducati.ms - The Ultimate Ducati Forum
Old Jan 31st, 2010, 9:46 pm   #1 (permalink)
Let me preface this question by stating that I'm a moron when it comes to do-it-yourselfing. I have only a few tools and even less patience.
That said, I'm thinking about buying Rizoma Rearsets and was wondering whether I could save money by doing the install myself. If its no more difficult than bolting and unbolting then I can do it.....anything more and I'd rather pay the shop.
Tomster the Duc is offline   Reply With Quote
Old Jan 31st, 2010, 9:57 pm   #2 (permalink)
I had a set of Rizoma rearsets for my Kawasaki and it was a straight forward bolt / unbolt job. If even I could do it, I am sure you should not have any problems!
froryde is offline   Reply With Quote
Old Jan 31st, 2010, 10:02 pm   #3 (permalink)
It's easy just unbolt the 2 nuts then slide out the old shaft and slide in the new one that comes with the sliders,work from the left side first place that slider on then the right side slider on then tighten the two bolts up and done.
that easy,it was for me.
it also come with instructions.
MADWOG is offline   Reply With Quote
Old Jan 31st, 2010, 10:07 pm   #4 (permalink)
Extended Member
CAlexio's Avatar
uhm... methinks you're a little confused madwog, but that's ok too. just keep your rearsets and your frontsets straight alright buddy?
Old Feb 1st, 2010, 12:25 am   #5 (permalink)
Crank1000's Avatar
Lol, it's tough though since they use stage reference, so the rearsets actually go on the front (stage rear) while the frontsets actually go on the rear (stage front). But the left and right sets use nautical reference though, as in port and starboard. You'll get the hang of it...
Old Feb 1st, 2010, 5:36 am   #6 (permalink)
HA HA HA HA, me think i need glasses thats what you get for reading it to quickly, Any Old How with rizoma it's pretty much straight forward and i find there instructions easy to follow.good luck with any part you put on rearsets or frame sliders.LOL
Old Feb 1st, 2010, 9:23 am   #7 (permalink)
Appreciate the info, guys. Perhaps I'll attempt the install myself afterall. Or at least take it to a buddy's so he can do it. Duc shop witll charge an hour's labor.
Old Feb 1st, 2010, 12:49 pm   #8 (permalink)
archimedio's Avatar
Installing rearsets is no big deal unless you're really mechanically disinclined. Three warnings.
1. Make sure you locktite everything.
2. Make sure you get the shift linkage adjustment right before locktiting the adjusters.
3. The hardest part is often the brake light switch. I don't use my rear brake anyway, so I just throw that away.
archimedio is offline   Reply With Quote
Old Feb 1st, 2010, 5:31 pm   #9 (permalink)
let me know if you going to sell your stock rearset
samizx7 is offline   Reply With Quote
Old Feb 2nd, 2010, 1:10 pm   #10 (permalink)
Site Sponsor
Motovation's Avatar
It's a bit more complicated than the other models but not hard. We're in Austin too so if you need help don't hesitate to let us know.
Authorized Distributor of Rizoma, SC-Projects, Motovation Protection Accessories.
"People don't do what they believe in, they just do what's most convenient, then they repent. - Bob Dylan, Brownsville Girl"
See us on Facebook!
Motovation is offline   Reply With Quote
rizoma rearsets opium654 StreetFighter 14 Jan 20th, 2010 3:50 pm
rizoma rearsets and passengers' pegs pics attached george_v HyperMotard 5 Apr 22nd, 2009 9:07 am
Rizoma rearsets broop HyperMotard 17 May 28th, 2008 1:54 pm
Rizoma Rearsets Installed on the 749s - pics inside SlewofDamascus Superbikes 14 Mar 3rd, 2007 9:19 pm
rizoma rearsets for 916? dragknt Superbikes 12 Nov 28th, 2006 11:15 am
