I believe there was a service update that relaxed the NEW belt tension to
120 Hz (+/- 5 Hz). Used belt tension is lower at 100 Hz (+/- 5 Hz) since the
used belts are already worn-in and won't stretch like a new belt generally does.
Keep in mind that the tension goes _up_ when the engine is hot due to the
expansion of the aluminum engine castings that the belt pulleys are mounted to.
The best advice for new belts I've heard is to just ballpark the tension around
105-110, leave the belt covers off, ride it for a few hours, then carefully set
the cold tension to 100-105 Hz again. Shouldn't have to worry about them
for a good 7500 miles at least.
'08 Hyper "S" w/ a few tweaks
