Hypermotard Headlight Adjust Instructions - Ducati.ms - The Ultimate Ducati Forum
Old Jan 16th, 2010, 7:24 pm   #1 (permalink)
There are two other threads in this forum on adjusting the headlight on the Hypermotard, but they are incomplete, and my adjustment is located in a slightly different spot than the one picture I saw.
1. Find some level ground at least 23 foot long with a wall at one end. I used the inside of my garage, which is perfectly flat.
2. Sit on the bike with all of your gear you normally ride with.
3. Have someone measure the distance from the ground to the headlight bulb.
4. Mark that distance on the wall, and make another mark 2 inches below that mark
5. Move the bike headlight exactly 17 feet from the wall with the markings, pointing at those markings.
6. Sitting on the bike with all of your gear and using low beam, the top of the light spot should be right on that mark 2 inches below the headlight height.
7. Hop off the bike and tilt the handlebars completely to the left.
8. Use a philips head screwdriver to adjust the light up or down as shown in the image below. Clockwise adjusts down, Anticlockwise adjusts up. WARNING: There is no limit stop the screw, so adjust in small increments. I adjusted mine by 4.5 turns in half turn increments.
The settings for the positioning of the light were gathered from my Google searches. Some said the light should be 17 foot from the wall, and others said 25 foot. I have not yet ridden in the night since the adjustment, but will post my results when I do.
I have not covered the left-right adjustment, as it was not needed in my case. The screw for left-right adjustment can be found by turning the handlebars completely to the right, and the screw is about 2 inches lower than the one shown in the above image.
MadBison is offline   Reply With Quote
Old Jan 17th, 2010, 7:05 am   #2 (permalink)
MTScott2's Avatar
Images: 5
I installed a $20,oo Silverstar 9003ST bulb one under the Silverstar ULTRA ..
Booklet says WATTS max65/72 ..colour J578 White..Lumens910/1500 +/-10% made in Germany
Better than the stock Phillips H4 60/55 WATT made in Germany bulb
Contact OSRAM SYLVANIA INC.
customer service 1-800-347-3420
275 West Main s
St Hillsboro NH 03244
2011 Red Multistrada Touring
Old Jan 18th, 2010, 2:40 am   #3 (permalink)
bullet3z's Avatar
Great thread. I wish this would have been around a year ago, would have helped a ton. My headlight was pointing towards the moon then. I could see everything up in the trees but I had no idea where I was going.
Osram bulbs are great. There is a difference between "Osram" and "Silverstars". True "Osram" bulbs are better than the normal Silverstars. I run the Osram Nightbreakers in my car and am vey happy with them.
Here is a nice little link for those of you looking for the correct bulb for our bikes. There are several names for this bulb in America.
http://candlepowerinc.com/pdfs/H4_9003.pdf
bullet3z is offline   Reply With Quote
Hyper Headlight Adjust shat HyperMotard 13 Jan 16th, 2010 8:41 pm
adjust headlight Darsey HyperMotard 2 Sep 21st, 2009 7:18 pm
HM Specs and Info SouthsideDuc HyperMotard 8 May 4th, 2007 10:58 am
Got some Hid and need to adjust headlight Cigarlvr Superbikes 3 Aug 12th, 2006 1:38 am
