fuel tank re-fit resulting in fuel leak - Ducati.ms - The Ultimate Ducati Forum
Old Jan 16th, 2010, 2:35 pm   #1 (permalink)
Hi.
After disassembling the fuel tank to install the air filter cover that came with the Termi exhaust I noticed that I have a fuel leak from the small left screw on the rear top area of the fuel tank (screw holding wire, see picture attached). I guess I should not have unscrewed the screws holding the wires but just open the metal strip. I alo probably over tighten the screw and now there is fuel coming out of it. Sh.t happens!!
I wouldn't like to replace the tank just for this also the screw is on top of the tank so i hope that I can glue something on top of the screw itself to stop the leak. Does anybody have a suggestion?
Thanks once more for the great help from the users of this forum.
Claudio
Claudio
___________________
Hypermotard 1100S
888 Strada
MV F4 750 EVO3
claudio is offline   Reply With Quote
Old Jan 16th, 2010, 4:10 pm   #2 (permalink)
Caidly's Avatar
Warranty
if you need to know... ask...
Old Jan 16th, 2010, 4:34 pm   #3 (permalink)
johnchypermotard's Avatar
Originally Posted by CTarna View Post
Warranty
how is an owner error in maintenance justified as a warranty issue?
Old Jan 16th, 2010, 4:46 pm   #4 (permalink)
AXE
AXE's Avatar
Details.
Out!
2008 Ducati Hypermotard
Old Jan 16th, 2010, 6:07 pm   #5 (permalink)
warranty
I'll try to speak to the shop where I bought the bike new in 2007. I guess the warranty is not valid any more anyway, and I guess I will be told I used too much torque instead of the 2Nm prescribed, but also what kind of fuel tank design is this, that this sort of things can happen ?
Anaway, I will also try with some epoxy (need to find one reistant to gasoline) and see if this works...
BLAST!
Claudio
___________________
Hypermotard 1100S
888 Strada
MV F4 750 EVO3
Repairing a leaking SS tank Rainman Supersport 58 May 10th, 2012 5:46 am
Repairing leaky rusted steel tanks Rainman Hall of Wisdom 14 Jan 6th, 2011 11:31 pm
748 Fuel Tank Leak CanAm66 Superbikes 13 Aug 4th, 2009 9:32 pm
Leaking fuel tank and coolant! mytrainerlarry Superbikes 4 Aug 16th, 2008 9:09 pm
999 Fuel Tank Removal Help Please? kabinski Superbikes 4 Feb 12th, 2006 11:26 am
