Jan 10th, 2010, 2:48 pm
best LED turn indicator upgrade ...
these LED upgrade kits are very cool. every hypertard owner in the bay area that has seen them installed on my hypertard has noticed them, and ended up purchasing them from this guy in california, who is the us distributor.
only sells on ebay ... ships right away, and the parts are super high quality and easy to install (screw driver and pliers are all that are required).
simple plug-n-play installation ... the LED PCB already has resistors installed, so you do not need to mess with the dash board setting for the rear indicators ... they flash at correct cadence as is.
http://cgi.ebay.com/ebaymotors/Ducat...#ht_500wt_1182
btw, no affiliation with this seller ... just passing on info on a great hypertard upgrade.
ciao,
johnc
Jan 10th, 2010, 2:57 pm
Do you think they could be easily adapted to the front? Tom
Jan 10th, 2010, 3:02 pm
Extended Member
interesting... but more interested for solution for the front. My intention is to remove hand-guards and find a turn-signal solution for the front like previous poster stated.
Jan 10th, 2010, 3:15 pm
that's well beyond my capabilities, but i bet that brad (reynolds_brad) could fabricate some molto cool carbon fiber hand guards that incorporate these LED boards ... and might even be able to fabricate clear or amber lenses for them.
Jan 10th, 2010, 3:16 pm
Extended Member
found the website the sells these... interestingly they have "alpha" and "beta" indicators... both of which seem to be identical. Can anyone figure out the reason for this/difference?
http://www.weiser-motorrad.com/en-us...?prod=wbeta002
Jan 10th, 2010, 3:20 pm
Sounds perfect. I'll try to contact Brad.
Jan 10th, 2010, 4:11 pm
2008 Hypermotard (red)
2010 Streetfighter (white)
TSI Manufacturing LLC
TSIMFG.COM
541.206.9773
Jan 10th, 2010, 5:51 pm
Nice, too bad I just finnished the front on mine with other LED indicators and resistors to match flash rate. I used the enduro headlight strap mount method, worked great. I also went with DP handguards, additional sliders, CRG LS mirrors, and some really cool VisionX LED spot driving lights mounted up on the DP guards. When I'm done wiring them I'll post a pic.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Jan 10th, 2010, 6:02 pm
I think ide go for something more like your setup John as these ones wouldnt really look good intagrated into a handguard.
Jan 11th, 2010, 2:32 pm
Home of vortex tuning
I bought the rear turnsigs for the 1125 Buell which are the same housings as the stockers but LED @ $46. or so. Pulled the lens screw, reflectors, and spade clips and replaced perfectly. My ECU won't hold the change from bulb to LED in the indc mode though and flashes faster. I bought two sets and plan to install the fronts too.
