Stompgrip or Techspec?? - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 8th, 2010, 2:57 am   #1 (permalink)
Decreasing Dave's Avatar
Images: 14
Anyone have these??
Pics and reviews??
Thanks,
Dave
My DOC Welcome Kit
Dave Yeski
CCS Southwest Expert #99
(apparently retired....)
2008 Hypermotard S Black!!!!
2006 Yamaha YZ450F Supermoto
Old Jan 8th, 2010, 11:22 am   #2 (permalink)
lelenb's Avatar
Images: 12
I had the Stompgrip and removed it because the edges started to peel up even after I prepped the area with alcohol. If you do use it try chamfering the edges first. Also I found the nubs to be more aggressive then I needed and that may have increased the edge lift.
Lelen
Hyper S
Old Jan 8th, 2010, 11:36 am   #3 (permalink)
Techspec for me. Had the 'snakeskin' kind on my last 6 bikes. Make sure to clean the surface with alcohol and don't apply on a surface that is too cold or too hot. I'm very happy with them although the interest on the Hyper seems limited. They look great on it though!
ilsrwy27 is offline   Reply With Quote
Old Jan 8th, 2010, 12:14 pm   #4 (permalink)
I have the Techspec on the Hyper, they work well. Just call them directly and order them. I think they are only $19 bucks so you can't beat that.
I have used Stomp and Techspec on my track 600rr and both work well, the Stomp tend to stick better, but once they are one time they are on there. The Techspec can be removed and repositioned.
The "clear" Stomp grips are hard to install without trapping air bubbles, which are visable on some color bikes and looks horrible in my opinion. I have always used the black Stomp grips and find the traction is actually better than the TechSpec for the track , but not needed on the street or really on the Hypermotard.
just my opinion...
mwtrogus is offline   Reply With Quote
Old Jan 8th, 2010, 4:51 pm   #5 (permalink)
dave2riff's Avatar
I use the clear TechSpec pieces, but trimmed to only cover the inset area
on the side fairings. I tend to dig my outside knee in when cornering, and the
leather was wearing away the paint. Yes, air bubbles can be an issue (I can
install them with just a few bubbles), but wearing thru the red paint is a
bigger issue. I also once used the piece for the rear light housing to protect
it from a tail bag on a 3-day ride... worked perfectly. Easy on, easy off.
'08 Hyper "S" w/ a few tweaks
Old Jan 8th, 2010, 5:54 pm   #6 (permalink)
Originally Posted by Decreasing Dave View Post
Anyone have these??
Pics and reviews??
Thanks,
Dave
Hey mate.I have the Tec-spec.Seem to be goood so far...and cheap as chips to.
bigmacduc is offline   Reply With Quote
Old Jan 9th, 2010, 8:46 am   #7 (permalink)
bromike666's Avatar
I prefer Stompgrip and had them on four different bikes. But, no matter how hard I tried they would peel after 4 months Now I have TechSpecs on my Hyper.
"I love the sound of a dry clutch in the morning"
10 F1098S Streetfighter
08 Hypermotard 1100S
08 Multistrada 1100S
07 SM610
bromike666 is offline   Reply With Quote
Old Jan 14th, 2010, 10:07 pm   #8 (permalink)
Images: 39
2009 Hypermotard S Black
mangler7 is offline   Reply With Quote
Pics of StompGrip Tank pads on 749 Dark? RtnlSltn Superbikes 2 May 22nd, 2009 6:27 pm
