Subframe removal step by steps ? - Ducati.ms - The Ultimate Ducati Forum
Old Dec 23rd, 2009, 11:17 am   #1 (permalink)
Hi chaps and a joyeux noel to you all. Having just received a lightweight rear subframe from www.febur.it i'd like to spend my in between festive moments fitting it to the beastie in the unheated garage..brrrr...
anyone got any step by step guidance or at least a snaggers brief??
Cheers chaps....
guess what. it's past the solstice so won't be long till summer comes whooo hoo
It's really dirty under the seat :-(
Karlr is offline   Reply With Quote
Old Dec 23rd, 2009, 4:39 pm   #2 (permalink)
hyperdookie's Avatar
Images: 9
Just do it.See subframe removal part two thread.
Old Dec 23rd, 2009, 4:44 pm   #3 (permalink)
Images: 9
Don't break/strip stuff Risotto must constantly be stirred.
Old Dec 23rd, 2009, 5:32 pm   #4 (permalink)
lol
Old Dec 23rd, 2009, 5:32 pm   #5 (permalink)
using basmati rice so not so serious
Old Dec 23rd, 2009, 6:00 pm   #6 (permalink)
bwhip's Avatar
I just pulled mine off last weekend. Like many Ducati disassembly projects, there will be a few points where you scratch your head and go "huh?" A few places where you have to pull things apart only in a certain sequence. Overall, it's not too tough. The only part that had me stuck a bit was trying to remove the top bolts that attach the subframe to the frame. The nut on the inside is difficult to access with an open-ended wrench, and the bolt extends well beyond that nut into a rubber spacer. Be patient, and you'll get there eventually...
Latebraker.com
bwhip is offline   Reply With Quote
Old Dec 23rd, 2009, 6:04 pm   #7 (permalink)
yak sounds nasty..that bit looked like the easy bit too...question is though did you burn your risotto?
Old Dec 23rd, 2009, 6:22 pm   #8 (permalink)
Images: 9
Like bwhip said, take your time.I think you said you have a Termi too.2-1 or 2-2, because that changes a couple of things too. If you start to loosen a bolt and it seems to get tight, stop. I remember a couple of places where a bolt is run though a captured nut in the sub-frame then an additional nut is used to hold another part in place.Good luck, Merry Christmas, and basmati doesn't have nearly enough starch content for a proper risotto.
Old Dec 23rd, 2009, 6:28 pm   #9 (permalink)
true but it tastes better....last mod is rizoma rearsets then i'm there
so far..kyle throttle tube
nichols flywheel
maxton cartridge
termi 2-1
my spanish rice was depleted
999 subframe. Mono vs. BiPo CSTX_ST4s Superbikes 14 Sep 30th, 2009 2:45 am
Subframe sliders & shortened termis infidel HyperMotard 7 May 26th, 2009 9:43 am
Corsa RS subframe - Help needed! (and subframe) TAftonomos Superbikes 6 Mar 30th, 2008 7:23 am
748-998 Subframe update 1fast750ss Superbikes 5 Jan 18th, 2008 8:04 pm
Ugh. Changing mono subframe to biposto subframe... Dana Superbikes 5 Nov 13th, 2007 5:15 am
