Wet Pod Filters and Performance. - Ducati.ms - The Ultimate Ducati Forum
Old Dec 18th, 2009, 11:00 am   #1 (permalink)
Has anyone been caught in the rain using pod filters similar to what is currently being used for the Ca-Cycleworks aftermarket filter and I assuming on the TPO and TPO Beast-R systems.
Reason for asking, is because I hear that when these filters get wet from moisture from the road, you might see a signficant decrease in the ability of the filters to flow air to the engine, where as if you had an airbox you might not be as susceptible to moisture issues.
With all the debate on the midsize tank, I just wanted to understand what I was potentially signing up for before I jump in feet first.
If you can answer my question, I would appreciate it.
SS65
Stainless65 is offline   Reply With Quote
Old Dec 18th, 2009, 1:03 pm   #2 (permalink)
GMP
I was concerned about this too with the Ducshop kit. They said its no problem. You can get water resistant Outerwear prefilters to go over the pods, or make your own.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Dec 18th, 2009, 1:35 pm   #3 (permalink)
Extended Member
CAlexio's Avatar
oh... would have been good to know. I've definitely been caught in the downpour and didn't have any covers for my pods... what do I do now?
Old Dec 18th, 2009, 1:46 pm   #4 (permalink)
I would think that you'd have to ride through a monsoon to worry about that.
dirkwrong is offline   Reply With Quote
Air Filters - Stock vs Aftermarket, and Airbox Resonance JEC Hall of Wisdom 5 Oct 26th, 2011 9:55 am
Performance air filters Dark749 Superbikes 4 Sep 18th, 2008 10:56 am
Scotts Performance Oil Filters JCPakBikes Sport Classic 50 Jan 26th, 2008 2:14 am
Testastretta Performance Filters Lost_In_Spice Superbikes 8 May 25th, 2007 9:10 pm
