Clutch Cover - Ducati.ms - The Ultimate Ducati Forum
Old Dec 14th, 2009, 5:54 pm   #1 (permalink)
Clutch Cover
Hi, I'm thinking of putting a slotted carbon fiber clutch cover, BUT only if there is a benefit to installing one.
I realize that the only reason would be to keep the clutch cool But is it nessasary???
What does the oem clutch look like in terms of style???? This is why I'm considering a carbon fiber slotted one . It still will vent cool air but not show to much of the oem pressure plate, assuming it's plane jane ( because everybody seems to run colored pressure plates). ????????????????????
gary hyp is offline   Reply With Quote
Old Dec 14th, 2009, 6:05 pm   #2 (permalink)
I would avoid a carbon cover man, for the simple fact that if the bike happens to go down on the clutch side it will destroy the cover and possibly the internals of the clutch.
Aswell as keepin the clutch cool it also prevents clutch dust build up inside the cover.
If your goin to get a slotted cover id invest in some stainless steel springs and caps, last thing u want is for the oem ones to rust and the oem clutch plate isnt to cosmetically ugly.
CarbonTard is offline   Reply With Quote
Old Dec 14th, 2009, 9:14 pm   #3 (permalink)
Thanks for that, I've been thinking about the same thing.
2008 Ducati Hypermotard, 1970 Suzuki TC 120 sold
2005 KTM Supermoto sold, 1972 Suzuki TS250 sold
2002 KTM Supermoto sold, 1972 BSA 500 sold
1968 Ducati 350MKIII Desmo, 1978 Suzuki GS550 sold
1979 Honda XL500 stolen
remery is offline   Reply With Quote
Old Dec 15th, 2009, 8:57 am   #4 (permalink)
You also have to deal with the extra noise from the clutch when you run an open cover. That's most likely a plus for most people, but it's too noisey for me.
andrewmr is offline   Reply With Quote
Old Dec 15th, 2009, 12:48 pm   #5 (permalink)
Banned
There is no good logical reason to run an open cover on the street. However I find the bad illogical reasons more than enough for me Style and sound... I wouldn't do the CF, not enough protection for some very expensive parts.
Old Dec 15th, 2009, 5:52 pm   #6 (permalink)
Will stainless steel springs increase clutch pull at the lever or it being hydraulic actuated keep that in check? Do you have a name brand in mind ??
Old Dec 15th, 2009, 6:07 pm   #7 (permalink)
Supero100's Avatar
Venting the friction material dust isn't logical? Improved cooling isn't logical?
Supero100 is offline   Reply With Quote
Old Dec 15th, 2009, 6:29 pm   #8 (permalink)
Supero100's Avatar
Only if your clutch parts are worn out or fit poorly.
On my former ST4s I ran an open cover with an MPL Tuning basket which had titanium inserts (to prevent impact concavity) and was machined to very precise tolerances, which fit my friction plates with almost zero margin. It was more quiet than any clutch I've heard, including closed covers.
I will be installing an NCR slipper into the hyper, and reusing the MPL basket. I'm interested to see how quiet that will run.
It's all relative, anyway. People still rolled their windows up near me when stopped at lights.
Old Dec 15th, 2009, 7:00 pm   #9 (permalink)
dave2riff's Avatar
If spring stiffness is increased the lever pull will be affected, even with the
hydraulic actuator. I believe the SpeedyMoto spring sets are the same stiffness
as stock, but there is at least one commonly available brand that is 10% stiffer
than stock. You can get a lever pull reduction by changing the clutch slave,
though the tradeoff is it takes more travel at the lever to move the clutch
plate the same distance. But in general, any increase in clutch spring stiffness
translates over to the lever pull, whether cable or hydraulic activated.
'08 Hyper "S" w/ a few tweaks
Old Dec 16th, 2009, 7:21 am   #10 (permalink)
Banned
Not necessary hence not a logical reason to spend the money. Nice benefits but not necessary by any stretch.
Dry Clutch Pressure Plate & Open Cover Installation Guide Rob998 Hall of Wisdom 54 Jan 16th, 2012 9:39 pm
FS: DP Racing Carbon Fiber Clutch Cover johnchypermotard HyperMotard 3 Nov 19th, 2008 7:14 pm
Solid clutch cover Arsey Sport Classic 21 Jun 28th, 2008 10:23 pm
EVR Slipper Clutch - MUST SEE!!!!!!!!!!!! wrichards Superbikes 20 Nov 20th, 2007 10:46 am
VENTED CLUTCH COVER and SPRING RETAINERS ISSUE. 996 ris Superbikes 10 Jul 24th, 2007 9:34 pm
