If you want to get the most out of your bike, the Nemesis or Microtec is the way to go. Since they are not an add-on like the DJ-PC, they respond faster to signal inputs and you have many parameters you can change/use (rpm limiter, gear based maps, ignition map, wideband tuning, etc)
You can use the maps provided or customize your own setup. Better have someone who knows what they're doing if you choose to customize, otherwise you could be in a world of hurt. Your ordinary Dyno Jet jockey probably won't cut it.
