Hooking up battery tender - Ducati.ms - The Ultimate Ducati Forum
Old Nov 15th, 2009, 10:33 am   #1 (permalink)
Just wanted to clear a few things up before I began the install.
I read through my owners manual and searched on here, we have a 12v battery and not a 6v correct? My last bike was a 6v and when I tried to charge it I fried it. I just picked up a new 12v battery tender jr and wanted to make sure before I hooked it up.
Also when I bought her, my dealer told me if I disconnected my battery they ecu would reset and would not start it again. I would have to get it towed to his shop so he could put the code in so I could start her again. BS or true?
Thanks for any help with my noobish questions
ICustomxXXI is offline   Reply With Quote
Old Nov 15th, 2009, 10:37 am   #2 (permalink)
12v and b.s.
motopix is offline   Reply With Quote
Old Nov 15th, 2009, 10:41 am   #3 (permalink)
Thought it may be bs. The manual says when charging the battery to disconnect it from the bike. Nothing about entering a code once you reconnect it. Does anyone actually disconnect the battery from the bike when charging or just plug and unplug?
Old Nov 15th, 2009, 10:53 am   #4 (permalink)
bikeaholic/farkleholic
raffyk's Avatar
I don't disconnect the battery. However I do have a fused lead with SAe end. I plug th Battery tender to the SAE connector. Never had a problem with all of the bikes I've charged this way..
Raffy
___________________
www.motogear4you.com
Current:
'08 Hypermotard 1100S
Termi+ECU
6.4 gallon tank
DP saddlebags, tailbag
Comfort seat
GPS mount
http://www.ducati-owners-group.com
Previous Ducatis: 996 ('01), 998 Matrix ('04), 900ssie('01), M900/985 ('97), 998 Matrix (same one '04), MTS1100S ('07), & MTS1000DS ('03),
raffyk is offline   Reply With Quote
Old Nov 15th, 2009, 11:26 am   #5 (permalink)
NickyD999's Avatar
Images: 4
I disconnect the battery from the bike. My bikes have to spend winter in a freezing wooden shed and I have never felt comfortable leaving the battery plugged in for fear that I will burn down my shed or something so I take the battery inside and hook it up to a charger in my basement.
No problems getting the 999 to fire up next spring, I can't imagine the Tard being any different.
2006 Ducati 999
2009 Ducati Hypermotard 1100
NickyD999 is offline   Reply With Quote
Old Nov 15th, 2009, 1:07 pm   #6 (permalink)
Just finished! Disconnected the battery, hooked up the charger and reconnected the battery, charged her for about an hour while I lost the charcoal box and she started up no problem. My dealer is weird....
Thanks everyone!
Old Nov 15th, 2009, 7:02 pm   #7 (permalink)
raffyk's Avatar
Glad it worked out.
Raffy
___________________
Current:
Termi+ECU
6.4 gallon tank
Comfort seat
GPS mount
Old Nov 16th, 2009, 5:47 am   #8 (permalink)
Caidly's Avatar
I took the battery out of the Hyper for 6+ months to "tend" it and when I put it back in, she started back up.
I am sure many others have, as well, when they put in the larger fuel tank.
if you need to know... ask...
Old Nov 16th, 2009, 7:09 am   #9 (permalink)
My dealer is weird....Thanks everyone!
He sure seems to be...
ilsrwy27 is offline   Reply With Quote
Old Nov 16th, 2009, 7:45 am   #10 (permalink)
Haha Has anyone else paid cash for a jacket and not received it till seven months later? I did!
Battery Blues, and DUCATI Electrical Stick Hall of Wisdom 15 Nov 14th, 2009 7:01 pm
Winter Battery Tender Question Indy36 Supersport 6 Nov 3rd, 2009 4:49 am
Battery Tender question yellow blur Ducati Motorcycle Chat 28 Feb 24th, 2009 6:11 pm
Battery Tender Jr. Quick Disconnect - not charging to 100% aa240sx Superbikes 12 Jan 17th, 2007 8:02 pm
Hooking up a battery tender receptacle archer Superbikes 5 Nov 15th, 2006 9:20 pm
