Hyper Foot Peg Removal: Help! - Ducati.ms - The Ultimate Ducati Forum
Old Nov 5th, 2009, 3:02 am   #1 (permalink)
Jeremy25056's Avatar
Just got my new SWAT foot pegs in. Any chance anyone could give me some help on removing the stock. It looks like just a pin with a spring??? does it need to just be knocked out??? any help would be appreciated.
Thanks much,
Jeremy
2008 Hypermotard (red)
2010 Streetfighter (white)
TSI Manufacturing LLC
TSIMFG.COM
541.206.9773
Jeremy25056 is offline   Reply With Quote
Old Nov 5th, 2009, 4:45 am   #2 (permalink)
londin's Avatar
Can't help you with the install but where did you get the foot pegs from?
londin is offline   Reply With Quote
Old Nov 5th, 2009, 5:06 am   #3 (permalink)
http://cgi.ebay.com/ebaymotors/ws/eB...9#ht_500wt_900
TSIMFG.COM
541.206.9773
Old Nov 5th, 2009, 7:50 am   #4 (permalink)
sick50ford's Avatar
Yes its just a spring, remove the c clip on one end and push out the shaft. They go back together pretty easy.
Edit: if you are having problems, When I did my pegs I had the peg mounts off the bike possibly making it easier? I never tried doing this with parts still attached to the bike
Old Nov 5th, 2009, 7:59 am   #5 (permalink)
hyperdookie's Avatar
Images: 9
I had to remove the clutch cover to pull the right side pin. I have a Speedymoto cover and it just wouldn't clear. Don't know if it's an issue with other covers.
Old Nov 5th, 2009, 10:38 am   #6 (permalink)
Confirmed Addict
v12gte's Avatar
Mine came out OK, without any issues or interference. A slight tap, and the pin was out.
If I recall....there was a circlip....For that....a set of circlip pliers is very handy (they work in reverse, jaws open when handles are squeezed and have two tabs for spreading the circlip open).
I mounted the shift-tech black pegs, and I now have more room for my Revit boots (extra adjustments did the trick).
2008 Hyper S
2006 MV Agusta Brutale 910s
+afflicted with "Mad Car Disease", too
v12gte is offline   Reply With Quote
Old Nov 5th, 2009, 12:03 pm   #7 (permalink)
I had to remove the clutch cover as well. Pin wouldn't clear. Other than that, pretty straightforward...
redscout is offline   Reply With Quote
Old Nov 5th, 2009, 12:25 pm   #8 (permalink)
johnchypermotard's Avatar
here is the manufacturer's site:
http://www.swattmotorcycle.com/HYPER_PEG.html
Old Nov 5th, 2009, 12:50 pm   #9 (permalink)
thanks for all the help guys! really appreciate it. il let you guys know how it goes today.
-Jeremy
TSIMFG.COM
541.206.9773
SF Foot Peg Solution? Adjustable Pegs? Shift-Tech StreetFighter 11 Jul 19th, 2009 10:15 pm
stuck rear foot peg Avanti Sport Touring 6 Jul 16th, 2009 4:32 pm
Need dimensions for fasteners for DR DESMO bar risers and foot peg lowering plates wildwestrider Sport Touring 9 Jun 2nd, 2009 6:05 pm
Foot Peg max911 Vintage 7 May 21st, 2009 12:49 pm
