Duc Shop Velocity Stack Kit - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Oct 28th, 2009, 2:28 pm   #1 (permalink)
GMP
Question Duc Shop Velocity Stack Kit
For those who have done this, is it worth it? I've seen the dyno curves, but I'm interested in opinions from street riders that use the entire range especially the mid, not track riders primarily looking for top end gains. I currently have an LV system, DP airbox lid, K&N filter, and DP 2-1 ECU.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Oct 28th, 2009, 3:16 pm   #2 (permalink)
crabman's Avatar
I've got a full Termi system and when I installed the Ducshop stacks BIG difference! My butt dyno told me the entire RPM range felt improved, namely the midrange. I think it was the best performance money spent.
2011 Multistrada S Touring Black
2010 BMW S1000RR Thunder Grey
crabman is online now   Reply With Quote
Old Oct 28th, 2009, 3:40 pm   #3 (permalink)
Performance Center
Ducshop's Avatar
We sold out the other day so our CNC guy is making another batch.
Old Oct 28th, 2009, 3:57 pm   #4 (permalink)
to get the best you'll need a power commander. I had them on the bike but the loss of throttle snap at low rpm without a PC made me take them off. (that and I was going deaf!)
they will go back on when i order my HC pistons, PC3/5, flywheel and cams.
Old Oct 28th, 2009, 6:13 pm   #5 (permalink)
Extended Member
CAlexio's Avatar
i have a ducshop built hypermotard, but I bought it with the velocity stack and everything else installed. I can't tell you therefore how much the V.S. by itself improves things... but it makes a huge loud f-in noise ( ) on acceleration.
Old Oct 28th, 2009, 6:30 pm   #6 (permalink)
Have you tried your stacks on other engines, like the 900ie?
dirkwrong is offline   Reply With Quote
Old Oct 28th, 2009, 7:15 pm   #7 (permalink)
disgo duc's Avatar
Images: 23
+1 on stacks i thinkthey sound great!personally i thought the hyper was to quiet to begin with i like loud and power range greatly improved.
Old Oct 28th, 2009, 7:59 pm   #8 (permalink)
NYSport's Avatar
Images: 4
I'm definitely interested in picking up this mod. Besides the potential gain (in conjunction with the PClll) I like the secondary benefit of cooling the aft jug a little bit. I do track the Hyper while I'm waiting to snag a 749r or s.
Old Oct 28th, 2009, 8:20 pm   #9 (permalink)
jboothe's Avatar
Question: Since the larger CACycle tank includes "pod filters" and gets rid of the air box, won't that give you a similiar performance gain?
On a side note, I was trying tonight to finish up my 7500 mile service. Removed the tank to clean the air filter and check the vertical cylinder valve clearances and I found 3 of the 6 screws in he top cover of the air box won't come out. The inserts are stripped in the plastic box. Tried prying up on the cover while turning and none of them would budge. Started getting late so I gave up and put it back together. Guess the previous owner or the local dealer was a little heavy handed. And since when I bought the bike the PO told me he had all the service done at the dealer. So where does that leave me? I'm pretty sure I won't be getting that air filter out without f$%#&*g up that air box.
Old Oct 28th, 2009, 9:08 pm   #10 (permalink)
GMP
No, just slapping a filter on the throttle body typically results in a loss. The point of the stack is to smooth and tune the flow. Sounds good to me, but Pedro's comment about lost low end snap is in contradiction to the others. The dyno curve doesn't support this either.
Glenn
'07 GasGas EC250
ST4s Ducati Performance kit - opinions please ducatiparts110mb Sport Touring 1 Mar 2nd, 2008 9:08 pm
ST3 Shop Manual Purchase Warning: the '04 - '05 conection stryder Sport Touring 6 Mar 10th, 2006 9:33 am
