190 rear tire on hypermotard question - Ducati.ms - The Ultimate Ducati Forum
Old Oct 26th, 2009, 8:20 pm   #1 (permalink)
Extended Member
CAlexio's Avatar
guys... does it fit? anyone tried it? about to take advantage of a pricing deal and it's ending quickly. need answer asap. GRAZIE!!!!!!
Old Oct 26th, 2009, 8:33 pm   #2 (permalink)
richmeyer's Avatar
im pretty sure a 190 will fit. it'll slow down the handling a bit though
WMRRA #621
2000 996
2010 SFS
Ducati Bellevue
Darren Beatty Photography
MOTOWHEELS
AMSOIL
Spy Optic
Mountain Khakis
richmeyer is offline   Reply With Quote
Old Oct 26th, 2009, 8:42 pm   #3 (permalink)
Extended Member
CAlexio's Avatar
we have one "pretty sure"... anyone know for sheezy? (that thing can handle a little slower turn-n methinks.)
Old Oct 26th, 2009, 9:44 pm   #4 (permalink)
I`m running a dunlop gpa 190.1 tooth down on the front sproket and she fits perfect.
lugger is offline   Reply With Quote
Old Oct 26th, 2009, 9:45 pm   #5 (permalink)
mooner's Avatar
I'm running a 190 tire, but its on a 6inch BST wheel. On long right hand turn on the track I have noticed the chain is shaving the edge of the tire. That was common on my supermoto race bike. You may want to consider is: http://www.sportrider.com/tech/tires...ire/index.html
2008 Hypermotard S
mooner is offline   Reply With Quote
Old Oct 26th, 2009, 9:58 pm   #6 (permalink)
NYSport's Avatar
Images: 4
Originally Posted by mooner View Post
I'm running a 190 tire, but its on a 6inch BST wheel. [/url]
Showoff
Old Oct 26th, 2009, 10:31 pm   #7 (permalink)
mooner's Avatar
Originally Posted by NYSport View Post
Showoff
They were my xmas present to my bike last year
Here's a pic of the were the chain scraped the left side of the tire
2008 Hypermotard S
Old Oct 26th, 2009, 10:45 pm   #8 (permalink)
Extended Member
CAlexio's Avatar
thanks Mooner!! I think my hyper could deal with a little more traction (or I could be a little more careful with my throttle) but mostly I like the look. I took off from a light a few days ago and did a full burnout in 1st gear... that was a first(unintended) from me on any bike... So maybe this 190 tire will tame that irrational exuberance a little
Old Oct 26th, 2009, 11:07 pm   #9 (permalink)
orion8419's Avatar
the gpa are made to fit on a 5.50-6.00 rim where as other 190 tires are just made for a 6.00 rim.. i think. i run the gpa's on my race bike(600) i would stick with 180 for the hyper
LRRS/CCS #135
08 hypermotard
- SC-Project full exhaust
- DP ecu
- CA cycle works 6.4 gallon tank
- rizoma clutch plate and cover
07 gsxr 600 track
orion8419 is offline   Reply With Quote
Old Oct 27th, 2009, 10:52 am   #10 (permalink)
archimedio's Avatar
190 on a 5.5" rim isn't going to give you any more straight line traction and, contrary to popular belief, doesn't slow your turn in. On the 5.5 rim the tire get's pinched, which changes the tire's profile, making it taller. Any width increase is offset by increased triangulation of the tire profile. And a more triangulated tire actually falls over quicker, not slower. There was a write up on this in Sport Rider a while back.
As others have said, your biggest issue is going to be clearance (and geometry if the tire is much taller).
archimedio is online now   Reply With Quote
190 rear tire on a HMs loudes13 HyperMotard 7 Aug 19th, 2009 8:00 am
Advice needed: rear suspension setup and tire wear Matt_P Superbikes 4 Jun 23rd, 2009 1:20 pm
Tire repair question gregcm Sport Touring 12 Nov 12th, 2008 6:55 am
Tire question -- basic gregcm Sport Touring 34 Sep 14th, 2008 12:08 pm
HM Specs and Info SouthsideDuc HyperMotard 8 May 4th, 2007 10:58 am
