I was tinkering with the new HM last night and decided to look at the clutch since I know the bike was driven pretty hard and it seems a bit grabby to me. Per the service manual it is supposed to have 6 driven plates and one spring plate that should be 1.5mm thick each.It should also have 4 drive friction plates should be a minimum of 2.6mm each. Then it goes on to state: "Caution:Overall thickness of the set of clutch plates should not be less than 46.1 mm" I'm not sure how they do their math in Italy but that just doesn't work.
http://picasaweb.google.com/lh/photo...eat=directlink
To further confuse me, I have 10 driven plates that measure around 1.5mm, No spring plate that I can tell and 8 drive plates that measure right 2.9mm. The driven plates are steel and the friction plates are aluminum. The whole pack measures a total of around 39mm. I am assuming the previous owner changed the clutch.
http://picasaweb.google.com/JandCBoo...eat=directlink
Are the original friction plates steel? How thick should the aluminum one be? They look pretty worn out to me but without something to compare them to, I have no idea.
