Error code !!! - Ducati.ms - The Ultimate Ducati Forum
Old Sep 21st, 2009, 2:42 pm   #1 (permalink)
sargie34's Avatar
Angry Error code !!!
Hi Newbie to the site, so hello gang.
Ive had the hyper for about 2 months or so...and i love it.
But the dreaded ecu light has come on over the weekend with the error code 2.2 pressure sensor error.
Does anyone know what the fault is.
Ive tried to look on searches but no joy !!
HELP.
sargie34 is offline   Reply With Quote
Old Sep 21st, 2009, 3:48 pm   #2 (permalink)
MTScott2's Avatar
Images: 5
Pressure sensor shorted to earth... Ground fault???
2011 Red Multistrada Touring
Old Sep 21st, 2009, 4:01 pm   #3 (permalink)
johnchypermotard's Avatar
check the tightness of your hypertard's battery terminal connections.
i have seen a few hypertard's exhibit strange dash display issues when the battery terminals were not fully tight, causing electrical anomalies.
Old Sep 21st, 2009, 10:22 pm   #4 (permalink)
Jeremy25056's Avatar
^^+1 heard the same.
2008 Hypermotard (red)
2010 Streetfighter (white)
TSI Manufacturing LLC
TSIMFG.COM
541.206.9773
Jeremy25056 is offline   Reply With Quote
Old Sep 22nd, 2009, 12:23 am   #5 (permalink)
sargie34's Avatar
Thanks guys, i will hava look later.
Old Sep 23rd, 2009, 10:18 am   #6 (permalink)
Caidly's Avatar
Pressure sensor is under the bill plastic and placed downside of the headlamp. Did you mess with your bulb at all recently?
if you need to know... ask...
Old Sep 23rd, 2009, 10:50 am   #7 (permalink)
sargie34's Avatar
I did take the bill off to clean it, so you have got me thinking now.
I take it then...i could of pulled on a wire?
Old Sep 23rd, 2009, 1:49 pm   #8 (permalink)
Caidly's Avatar
Worth taking the 15 mins to take apart and look.
Old Sep 26th, 2009, 1:44 pm   #9 (permalink)
sargie34's Avatar
Well i did my checks and a big thanks to CTarna.. Took his advice and took the bill off to check the connection on the sensor and yes it had worked loose, so clipped it back on.
Not been out yet for a test run, but turned the engine over...NO ECU LIGHT.
So will give her a run tomoz and hopefully its sorted...touch wood.
Thanks for the advice guys !!!
Old Sep 26th, 2009, 3:09 pm   #10 (permalink)
cool beans. check the battery terminal connections too, just to be safe.
