Start flaming me now - stupid question - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Sep 10th, 2009, 11:50 am   #1 (permalink)
I tried to look in the manual (owner, not service manual) and tried searching through these threads but didn't find instructions for putting in a new air filter on the Hyper. I took some of it apart last night and it looks like the air box is under the gas tank (after taking off a lot of body work). Is that right? Do I have to remove the gas tank just to change the air filter?
Noob at this Ducati stuff and only have about 900 miles on the Hyper, so I suppose I'm due some newbie flaming, but I guess it's worth it for good info.
Thanks!
redscout is offline   Reply With Quote
Old Sep 10th, 2009, 12:11 pm   #2 (permalink)
Suigeneris's Avatar
You are correct but, the gas tank also has the wiring harness attached so its very difficult to move. I had the wife hold it up while I changed mine out. theres like 4 screws that are a bit tricky. So, I'd call a friend.
2008 Hyper "S"
Suigeneris is offline   Reply With Quote
Old Sep 10th, 2009, 12:18 pm   #3 (permalink)
Thanks
I was afraid of that... I suppose I could insert something here about the poor design of that little issue, but since the manual doesn't even show the filter needing any attention until 7500 miles I guess they just didn't think it needed to be easy.
Appreciate the info...
Old Sep 10th, 2009, 12:30 pm   #4 (permalink)
bikeaholic/farkleholic
raffyk's Avatar
Try changing the air filter on a BMW K1200LT. Stupid design. It's under the gas tank also. You would need to remove tip over bars and their cover, the wind wings, mirrors upper body panels, oddments box and surrounding stingray, driver's seat, wires, gas tank.
For a noobie a daunting task that could take 2 hours. For a seasoned person about an hour. BMW service for a 12K is like $900. Parts are around $160. Rest is labor at book rate.
Raffy
___________________
www.motogear4you.com
Current:
'08 Hypermotard 1100S
Termi+ECU
6.4 gallon tank
DP saddlebags, tailbag
Comfort seat
GPS mount
http://www.ducati-owners-group.com
Previous Ducatis: 996 ('01), 998 Matrix ('04), 900ssie('01), M900/985 ('97), 998 Matrix (same one '04), MTS1100S ('07), & MTS1000DS ('03),
raffyk is offline   Reply With Quote
Old Sep 10th, 2009, 12:45 pm   #5 (permalink)
GMP
You can do it without removing the tank. I removed all the bolts (don't forget the large one in the rear), lifted the front, and proped the tank up on a piece of wood jamed between it and the frame. There is just enough room to get the cover off and filter out. I did this to swap out a new K&N filter when everything was new and clean. If your servicing a dirty filter I'd remove the tank as you can't see as well and be sure dirt did not fall into the airbox.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Sep 10th, 2009, 1:57 pm   #6 (permalink)
Will do...
Thanks guys. This bike is still pretty clean. Just putting the K&N in there. Sounds like a pain in the butt, but at least it doesn't have to be done very often.
Old Sep 11th, 2009, 12:37 am   #7 (permalink)
lelenb's Avatar
Images: 12
If you have a small vacuum hose attachment suck out the center of the air filter before you remove it to get any loose debris especially small pebbles as they can fall into your air box and get sucked in the engine. The Hyper filters from the middle not the outside of the filter like most airboxes.
Lelen
Hyper S
Old Sep 11th, 2009, 10:52 am   #8 (permalink)
Jeff4510's Avatar
I'm about to change mine ut for the 7500 service, anyone drilled some holes in he box for better flow?
08 HM S
05 CR500AF street project
05 CRF450X super moto/streeted
1985 Vespa ETS 125
1977 R100/7
Jeff4510 is offline   Reply With Quote
999 Crank No Start No Codes Structure3230 Superbikes 0 Sep 10th, 2008 8:17 pm
Stupid Question kmh364 Ducati Motorcycle Chat 12 Aug 10th, 2007 2:35 pm
Stupid Noob question. Mr_Chow Superbikes 4 Jul 24th, 2007 5:48 pm
748 a stupid question? dunlop0_1 Superbikes 8 May 31st, 2006 8:12 am
Another stupid oil change question (filter angulation)... macc4s Sport Touring 4 Jan 16th, 2006 12:16 am
