anyone run the cam euc without cams - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Sep 9th, 2009, 1:41 pm   #1 (permalink)
I'm wondering if anybody has tried the cam ecu with only a full exhaust and no cams?
TIA
testa is offline   Reply With Quote
Old Sep 9th, 2009, 1:59 pm   #2 (permalink)
I'm running the cams ECU with only the airbox mod, K&N filter and LV cat eliminator, stock exhuast. I had the tps reset and fuel trim set at the dealer and it seems to run great.
JayBay13 is offline   Reply With Quote
Old Sep 9th, 2009, 2:39 pm   #3 (permalink)
lelenb's Avatar
Images: 12
I am running with DucShop Hyper pods and a cored stock exhaust. It rips, no problems what so ever.
Lelen
Hyper S
Old Sep 9th, 2009, 3:30 pm   #4 (permalink)
disgo duc's Avatar
Images: 23
should be fine especialy if you have it remapped with power commander.without remapping and power com. it will run alittle rich.
Old Sep 9th, 2009, 4:37 pm   #5 (permalink)
johnchypermotard's Avatar
TIA
i have been using the DP cam ECU with DP termi 2-1 full exhaust system, without installing the DP race cams.
have had my hypertard setup like this for about 8,000 miles ... works great.
fwiw, i just dropped my hypertard off to get the 15,000 mile service, and will have the DP race cams installed at this time.
ciao,
johnc
Old Sep 9th, 2009, 5:30 pm   #6 (permalink)
rummaggio's Avatar
conversely, if I might slightly take this off course - can the cams be run on the stock ECU?
2006 800ss
rummaggio is offline   Reply With Quote
Old Sep 9th, 2009, 8:26 pm   #7 (permalink)
GMP
That I would not do.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Need to ID some 999 Cams 993twin Superbikes 4 Sep 1st, 2009 10:08 am
749R Cams vs. 999R Cams ??? SittingDuc Superbikes 4 Aug 14th, 2009 11:55 pm
Cam timing numbers for DP cams? Lumpy Idol HyperMotard 3 Aug 19th, 2008 5:43 pm
DP race cams yota HyperMotard 36 Dec 1st, 2007 3:16 pm
