DP ECU with stock exhaust? - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Aug 29th, 2009, 6:45 am   #1 (permalink)
HyperGirl's Avatar
Question DP ECU with stock exhaust?
I am experiencing popping on the decel, and I assume this is because of the lean air/fuel mixture .....
I have read on this forum that folks solve this problem by getting an aftermarket exhaust and DP ECU, but, I like the stock exhaust
So, is it possible to get a DP ECU (and keep my stock exhaust)?
And is the answer is Yes, where do I get one?!
HyperGirl is offline   Reply With Quote
Old Aug 29th, 2009, 8:23 am   #2 (permalink)
krill's Avatar
Yes it will but a fat duc will do the job much cheaper
krill is offline   Reply With Quote
Old Aug 29th, 2009, 12:43 pm   #3 (permalink)
HyperGirl's Avatar
Oooohhhhh, I see...... my apologies to all for asking an already much discussed question I didn't realize the function of the fatduc was to deal with the air/fuel mixture! Sweeeeet
So, even though the fatduc does the job cheaper, is there any downside to using the fatduc versus getting the DP ECU?
And, I guess I'm still curious about my original question:
Can we use the stock exhaust and DP ECU? Has anyone out there done this, and what are your results?
Thanks!
Old Aug 29th, 2009, 7:18 pm   #4 (permalink)
Home of vortex tuning
CDONA's Avatar
The 308B slipon ECU would be the better choice of the three DP ECUs with stock pipes & opened airbox, tune-able for flapper and O2 probe, fuel range will suffer, + better wheelies. That setup would benefit with a LV cat eliminator, no flapper pipe for best results
www.ducati.ms/forums/showthread.php?t=71331
Old Aug 30th, 2009, 9:17 pm   #5 (permalink)
GMP
I"ve done this and its fine, solves all the lean problems and the bike runs way coolerand smoother. A big advantage is if you want an exhaust later your all set.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Aug 30th, 2009, 9:53 pm   #6 (permalink)
HyperGirl's Avatar
Whoa there, cowboy! This is some great stuff ... 'esplain pleeze:
(you don't have to really, but, if you have the time and patience, I'm ready to learn
1. What's a flapper and what does it do?
2. What's an 02 probe and what does it do?
3. What's an LV cat eliminator and what does it do?
4. Which pipe does the 308B slipon ECU come with?.... is there a link for this one?
Oh, I have the large tank, so, I don't have an air filter box anymore...
thanks!
Old Aug 30th, 2009, 11:44 pm   #7 (permalink)
doon's Avatar
thanks!
If your airbox has been removed you should go with the Dp slipon or full system ecu!
The flapper valve is for noise emmisions, best if you remove it when you get aftermarket headers, another reason for dp ecu. LV =LEO VINCIE
o2 probe controls fuel mixture when running stock ecu, remove and unplug it when running aftermarket headers with dp ecu.
Any aftermarket pipes can be run with dp ecu's
The reason you are running lean is because you are getting more air in because of the airbox removial thus popping from exhaust.
Best you get a dp ecu, that will cure your leaness, then you can get aftermarket headers , slipons or full system at your whim.
Or get a full system that comes with dp ecu.
doon is offline   Reply With Quote
Old Aug 31st, 2009, 11:36 am   #8 (permalink)
HyperGirl's Avatar
Ohhhhhhhh
Thanks for taking the time to educate a new Hyper owner!
I really appreciate all the positive support on this Forum
Old Aug 31st, 2009, 4:01 pm   #9 (permalink)
doon's Avatar
Ohhhhhhhh
Your welcome, second hand dp ecu's go for about $300, try fleabay or ask on here if some one has one for sale.
TPS will need to be reset after installing.
Old Sep 8th, 2009, 11:35 am   #10 (permalink)
I have a slipon ECU for sale if you're interest. pm me. Cheers.
DrRipper is offline   Reply With Quote
ECU and exhaust combos revisited Treadmarks HyperMotard 35 Jul 21st, 2011 10:55 pm
Exhaust Modifications....stock! DonnyO Sport Touring 28 Oct 22nd, 2010 7:12 am
Stock Cans and Stock ECU available Hypremotard HyperMotard 0 Sep 19th, 2008 9:37 am
Stock ECU and exhaust available, cheap cincykid HyperMotard 0 May 28th, 2008 6:58 am
exhaust & ecu install speedfreak HyperMotard 7 Apr 3rd, 2008 9:57 pm
