190 rear tire on a HMs - Ducati.ms - The Ultimate Ducati Forum
Old Aug 17th, 2009, 7:17 am   #1 (permalink)
loudes13's Avatar
Anyone run a 190 rear tire on a HMs? My tire source for trackdays is saying that all 600, 750, and 1000's now run a 190 for trackdays and racing. Does the HM have 5.5" wide rear rim?
www.allenskillicorn.com
loudes13 is offline   Reply With Quote
Old Aug 17th, 2009, 8:38 am   #2 (permalink)
dragoontwo's Avatar
yes it has a 5.5" rear, just know that your speedo reading will be off.
Mike
1982 280ZX turbo
1990 Daytona VNT
1992 Subaru SVX
2000 Frontier
2006 KLR650
2008 Ducati Hypermotard 1100S
dragoontwo is offline   Reply With Quote
Old Aug 17th, 2009, 8:46 am   #3 (permalink)
kingsnake1650's Avatar
You will also have to adjust your ride height in the rear.... the 190 will be a bit taller causing the rear of the bike to be higher.
kingsnake1650 is offline   Reply With Quote
Old Aug 17th, 2009, 12:29 pm   #4 (permalink)
mooner's Avatar
I'm running a 190 tire, but on a 6 inch rim. Be warned some 190's are wider than others. This is a Bridgestone BT016, my track has a lot of long right handers. This allows the chain shave on rubber from the tire's edge.
Had the same problem with my KTM Supermoto bike
2008 Hypermotard S
mooner is offline   Reply With Quote
Old Aug 17th, 2009, 12:58 pm   #5 (permalink)
wjn
wjn's Avatar
Images: 11
Depends on the tire, but in generic, the wider the tire is, the more you must lean over for the same corner speed. Just physics.
And ground clearance is a problem with the stock Hyper.
Just buy decent track tires, like Bridgestones BT003 or Pirelli Dragon Supercorsa Pro.
Difference between sport street and race tires:
Stock Pirelli Diablo Corse III after one day Assen - NL:
Was my first track day on the Hyper, so not so fast at all.
Racing Supercorsa after 3 trackdays in Alès - France:
For the record, did 1:34 laps between supersports/-bikes
2008-07: Hypermotard 1100s Black (~98whp)
wjn is offline   Reply With Quote
Old Aug 18th, 2009, 9:34 am   #6 (permalink)
Just got 100mph plus from a local revenue collector.I`m runing a dunlap 209 190.Do you know how much the speedo`s off. thanks luger.
lugger is offline   Reply With Quote
Old Aug 18th, 2009, 9:34 pm   #7 (permalink)
freezer16801's Avatar
wjn, you may want to check your rebound in the rear. It looks like you are getting some abnormal rebound wear indicated by the balling up of rubber on the backside of the tread groove and the chamfering on the leading edge coupled with a clean portion before the chamfered portion.
I am ready to switch to the power ones for next season. I've used the DCIII's for the past couple of years and I think I am on the verge of outriding them on the track. One model of the power one claims that tire warmers aren't a necessity and they can be used on road and track. We will see.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Aug 19th, 2009, 8:00 am   #8 (permalink)
wjn
wjn's Avatar
Images: 11
Thnx I will check that.
Actually I did nothing yet with the suspension settings, other than making front and rear going more or less in sync.
Spend the most of the time working on my seat position on this bike.
Rear Tire Mileage Post (Data) chris410 HyperMotard 74 May 19th, 2009 9:40 pm
doing a rear tire change bgkykingpin Supersport 2 Feb 23rd, 2009 8:32 am
replace rear tire 06 999 osayek Superbikes 4 Oct 7th, 2008 3:21 am
Sport touring tire WYDuc Sport Touring 66 Sep 15th, 2007 11:36 am
