Battery held in? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!SportbikeTrackGearGraves Motorsports
Old Jul 1st, 2009, 8:15 am   #1 (permalink)
Battery held in?
Can anyone take a picture of their battery or describe how it's tied down?
Mine seems to just be sitting there loose under the seat and I am wondering if I'm missing a strap or anything.
italianpower is offline   Reply With Quote
Old Jul 1st, 2009, 10:21 am   #2 (permalink)
There is a hold down that the dealer is supposed to retro fit, under recall, I believe. I have one on my 08. The part number for the screw is 77915581A. I was given this number by the tech at the Ducati shop in Brea.
trrgod is offline   Reply With Quote
Old Jul 1st, 2009, 10:31 am   #3 (permalink)
Oh really? I just didn't see anywhere to attach a bracket to, is there a bracket also? Is the bracket in this fiche? Help please; need part # to battery tiedown bolt Thanks for the info, I will call a dealer.
Has anyone else gone in for this?
Old Jul 1st, 2009, 10:53 am   #4 (permalink)
You're gonna love my nuts...
Borracho's Avatar
I still had my battery tie down bar so I just went to the local hardware store for the new stuff.
M5 bolt with a .8 pitch, 30-35mm in length. I added two washers and a nyloc nut.
Photos:
Borracho is online now   Reply With Quote
Old Jul 1st, 2009, 10:57 am   #5 (permalink)
So there is a tie down bar? Which part is it in the fiche, or do you have a photo? What do you mean the new stuff, how come you had to get new bolts?
Old Jul 1st, 2009, 11:17 am   #6 (permalink)
Borracho's Avatar
Let me check the fiche; I don't think I saw it.
UPDATE: there is no battery bracket on the parts fiche. I went front to back and back to front, nada.
Sorry; missed your last question. The stock bolt sheared off at the bolt head when I went to remove my side carbon guard. New stuff just meant new hardware; the 30mm bolt, washers and nyloc nut.
Old Jul 1st, 2009, 11:35 am   #7 (permalink)
Yes, I sure don't have that bar.. I wonder if the dealer knows what it is if it's not on the fiche.
What online fiche were you using? I have a few other parts I'd like to look up.
Thanks for the help and the excellent pics.
Old Jul 1st, 2009, 11:40 am   #8 (permalink)
Borracho's Avatar
I'll PM you info.
Old Jul 4th, 2009, 8:00 am   #9 (permalink)
Battery strap - dealer recall
The battery tie down was fitted as part of a recall on '07 machines ie those not fitted with them at the factory. Not sure about the US but this def happened in Europe.
Your dealer should be able to find details.
Regards
Rob
Peak District
UK
vulpine3 is offline   Reply With Quote
Old Jul 4th, 2009, 11:33 am   #10 (permalink)
The bracket in the picture is correct. Your dealer can get one for you. Also, the fix includes velcro to attach to the bottom of the battery to help hold it from vibrating. You will find that a lot of small sandy stuff will accumulate below and around the battery bottom, over time this stuff will act as sandpaper and dig into the battery and/or gas tank. Not the best design. Someone should design an after market shield so that no stuff gets there. I also had the stock bolt/screw top break off. I also replaced it with one from the hardware store. I got the part number after I had already done my own fix. I want the dealer to get the proper bolt for me though.
How To: Install an Odyssey PC680 Battery in your 1995-2002 Superbike! mpaschetto Superbikes 26 Sep 2nd, 2010 8:10 pm
How To Install an Odyssey PC680 Battery in your 1995-2002 Superbike! mpaschetto Hall of Wisdom 26 Nov 25th, 2009 6:20 am
Battery Blues, and DUCATI Electrical Stick Hall of Wisdom 15 Nov 14th, 2009 7:01 pm
Bikemaster BTZ7S Lightweight Battery SAC Superbikes 3 Nov 22nd, 2008 9:43 pm
!!!! Possible Gas Tank / Battery Damage!!!!!! 08hyper HyperMotard 13 Jan 15th, 2008 1:23 am
