Hydraulic Clutch Conversion - Ducati.ms - The Ultimate Ducati Forum
  • 2 Post By zibbit u2
post #1 of 5 (permalink) Old Apr 19th, 2017, 3:39 pm Thread Starter
Anyone ever done a hydraulic clutch conversion on their 939/821 Hyper? Just curious if anyone else has had success in doing this.. it's on my to-do list, admittedly not very high on the list, but it's there nevertheless. Thanks!
Sent from my iPad using Tapatalk
Vtwinftw is offline
post #2 of 5 (permalink) Old Apr 19th, 2017, 4:03 pm
RetardedTiming's Avatar
I started buying parts but have been stumped at the slave cylinder. Magura makes one but I want to use my Brembo master because I want specific levers. The problem is neither are compatible with each other. One uses mineral oil the other brake fluid. The seals are designed for the fluid being used. You could do it if you just used a complete Magura system.
Sent from my LG-H901 using Tapatalk
-Dak
RetardedTiming is offline
post #3 of 5 (permalink) Old Apr 19th, 2017, 4:52 pm Thread Starter
I found a kit online by DucaBike that has everything but the slave, but they also sell an Oberon slave separately. See the links below:
Clutch kit:
http://motowheels.com/i-23899733-duc...scrambler.html
Slave Cylinder:
http://motowheels.com/i-7189544-ober...er-ducati.html
Thoughts?
Vtwinftw is offline
post #4 of 5 (permalink) Old Apr 19th, 2017, 9:30 pm
zibbit u2's Avatar
Clutch kit:
Ducabike Hydraulic Clutch Kit: Hypermotard/Hyperstrada 821-939 / Scrambler/
Slave Cylinder:
OBERON Clutch Slave Cylinder: Ducati
Thoughts?
That slave cylinder definitely won't work. You need to look at how the Magura Hydraulic Clutch conversion for dirt bikes work.
I'd say consult this document on building your own setup:
http://www.magura.com/media/2304/mag...015_en_web.pdf
HyperJB and Vtwinftw like this.
zibbit u2 is online now
post #5 of 5 (permalink) Old Apr 20th, 2017, 6:17 am Thread Starter
Thanks!
Vtwinftw is offline
Human Verification
EVR Ducati 48T Conversion Plates & Clutch Basket Sets moto Vendor Specials and Group buys 0 Mar 6th, 2017 9:24 pm
RIZOMA Grips moto Vendor Specials and Group buys 1 Mar 5th, 2017 8:52 pm
EVR Ducati 48 Tooth Plate & Clutch Basket Sets moto Motowheels 0 Jun 22nd, 2016 8:50 pm
STM Dry Slipper Clutch Kit: 1199/1299 w / Basket, Plates, & Magnesium Case moto Motowheels 0 Jun 4th, 2016 8:24 pm
STM Dry Slipper Clutch Kit: 1199/1299 w / Basket, Plates, & Magnesium Case moto Motowheels 0 Feb 16th, 2016 4:12 pm
