14t vs 15t sprocket- RPM@ speed - Ducati.ms - The Ultimate Ducati Forum
Old May 17th, 2009, 9:43 pm   #1 (permalink)
just wondering
i run a 14t sprocket and spend most of my time on the expressway in the 70-80mph zone. i'm returning around 30mpg. looking to improve on that a bit and relax the revs a little at speed.
what do you who run a 15t see for rpm @ say 75mph?
thanks for the help.
kyle
kyle_01 is offline   Reply With Quote
Old May 17th, 2009, 10:06 pm   #2 (permalink)
I'm running the stock 15T and seeing around 43 mpg cruising mostly at 75 mph. I have a 30 mile commute, 22 of which is highway and I run around 75 mph.
Your results, of course, will vary.
Swodi is offline   Reply With Quote
Old May 17th, 2009, 10:11 pm   #3 (permalink)
Hypremotard's Avatar
Originally Posted by kyle_01 View Post
just wondering
kyle
Mileage depends on bike config. I have the stock gearing - I will keep an eye out and let you know. I understand that the 14t front renders 6th gear pretty useless as the ratio closely matches 5th whcih would account for your high revs.
  • '08 Hypermotard S
  • '03 Monster 800 (Gone!)
  • '98 HD Fatboy (Gone!)
  • '95 HD Road King
Hypremotard is offline   Reply With Quote
Old May 17th, 2009, 10:20 pm   #4 (permalink)
08hyper's Avatar
I think the biggest difference in mileage is in the ECU, I have the cams ECU & my mileage is in the toilet, I only get 70mi or less before the light comes on, and my gearing is stock. Aloha Alex
Old May 17th, 2009, 10:27 pm   #5 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
I can say that, in your case, it's not the ECU it's the rider.
-Marco
Da_Bull is offline   Reply With Quote
Old May 17th, 2009, 10:33 pm   #6 (permalink)
08hyper's Avatar
Cool
Allright smartass, I'll be seeing you at the track real soon! with my motor of death, Aloha Alex
Old May 17th, 2009, 10:57 pm   #7 (permalink)
I have the 2-1-2 ECU and the light comes on at 75 and I put in 2.6 gallons to fill. What's the average refill when you hit the light? I think I need to run it out of gas to learn where it runs out of gas...... Not too keen on doing it though.
  • '08 Hypermotard S
  • '95 HD Road King
Old May 17th, 2009, 11:07 pm   #8 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
What's your fuel trim set at? I ended up setting mine at -3 and it improved mileage a little. I did add fuel to the curve at mid rpms/throttle openings and also leaned it out higher rpms/75%+ throttle openings. These adjustments were based on a dyno run with a sniffer up the pipe. The air/fuel ratio showed a richer than desired ratio at lower rpms, some leaness in the middle and way rich on top. This is with the cam ECU (stock cams) and Beast R.
I get close to 80miles before the fuel light comes on. A lot depends on how you're riding. If you're WFO all the time, your mileage is always going to suck, regardless of gearing.
Old May 17th, 2009, 11:41 pm   #9 (permalink)
Define WFO? basically, when the brake is off, the throttle is on. Kind of like a computer 0 - off 1 - on.... I don't quite understand the design of this throttle. You have to turn it so far to be on.... Weird.
  • '08 Hypermotard S
  • '95 HD Road King
Old May 18th, 2009, 9:45 am   #10 (permalink)
08hyper's Avatar
Sorry Peter, I don't know, I had the dealer set it up, even with the cams, she seems to run a tad rich, but for now thats OK, better rich than sorry, I'll know better after my dyno runs, (lots of them) Aloha Alex
Street Riding-"The Pace" zooom Hall of Wisdom 48 Nov 29th, 2011 6:47 pm
15t to a 14t Front Sprocket DragonNester Multistrada 8 Mar 17th, 2009 11:34 pm
"Killer" riding group lifes_an_ocean Sport Touring 26 Apr 15th, 2008 8:11 am
