Clutch shaft nut torque - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old May 15th, 2009, 1:42 pm   #1 (permalink)
Brainfry's Avatar
Say that fast 10 times....
Anyway, I've searched through here and in the service cd, but can't seem to find the specs on the main inner nut that goes on the main shaft in the clutch. That, or I simply don't know what it's officially called. At any rate, I've heard everything from 170ft lbs to 100ft lbs. It's the 20mm x 1. I can't even find anything with a spec higher than 100ft lbs in that torque section. Puzzling.
Anybody got the right figure?
Thanks!
B
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Brainfry is offline   Reply With Quote
Old May 15th, 2009, 2:37 pm   #2 (permalink)
Caidly's Avatar
Look around here:
http://www.ctarna.com/Ducati/HyperMotard/
if you need to know... ask...
Old May 15th, 2009, 2:41 pm   #3 (permalink)
Caidly's Avatar
#18?
Old May 15th, 2009, 4:05 pm   #4 (permalink)
Brainfry's Avatar
Originally Posted by CTarna View Post
#18?
That's the one... or one like it. Same useage.
'05 BMW K1200LT
'10 BMW S1000RR
Old May 15th, 2009, 4:08 pm   #5 (permalink)
Brainfry's Avatar
I have to assume it's a crankshaft gear fixing nut... 190nm...
'05 BMW K1200LT
'10 BMW S1000RR
Old May 15th, 2009, 4:19 pm   #6 (permalink)
Caidly's Avatar
That is what I was thinking as well. Just use common sense, if it is getting ridiculously hard, stop!
Old May 15th, 2009, 7:13 pm   #7 (permalink)
sick50ford's Avatar
i did mine last week. i torqued her down with three quick blips of the trigger on the 1/2" impact. + or - a blip. seems like its still good after 600 miles
Old May 15th, 2009, 9:13 pm   #8 (permalink)
Brainfry's Avatar
yeah, I'm trying to avoid that... I'm fine taking it off with an impact, just leary putting it back on.... I think I'm good at around 130 ft lbs with a torque wrench... and high strength loctite... we'll see come Sunday if it spins off on the track.
Thanks all,
B
'05 BMW K1200LT
'10 BMW S1000RR
Old May 15th, 2009, 11:01 pm   #9 (permalink)
sick50ford's Avatar
THats good to hear, my impacts runs about 130lbs. But I don't recall if I used loctite on that one though..
Old May 15th, 2009, 11:19 pm   #10 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
I tightened mine to 170nm with a big ass torque wrench per the instructions that came with my slipper clutch.
Clutch torque clutch Superbikes 5 Oct 31st, 2008 6:42 pm
What torque for the clutch basket nut EarthBM HyperMotard 4 Oct 10th, 2008 12:56 pm
STM slipper install guide for your HM. desmoworks HyperMotard 14 Oct 23rd, 2007 7:46 pm
Clutch spring torque?? PieEater Superbikes 17 Feb 7th, 2007 10:54 pm
