termi 2-1-2 servo/flapper - Ducati.ms - The Ultimate Ducati Forum
Old May 6th, 2009, 11:23 am   #1 (permalink)
sinex's Avatar
Spoke to dealer today, i am still trying to get to the bottom of this, he says servo motor is disabled with the slip on ECU at 3,500 rpm or when moving, but It's cycled upon key turn on to clear itself of any carbon build up, but remains open from there on, so removing from the loom would throw a fault light
sinex is offline   Reply With Quote
Old May 6th, 2009, 3:07 pm   #2 (permalink)
typhon's Avatar
Images: 9
i'm curious to find out what is going on with this too. i purchased mine used w/ the termi system, dp ecu and airbox lid already installed. i was under the impression that all of the extraneous bits had been removed. i guess not
typhon
typhon is offline   Reply With Quote
Old May 7th, 2009, 2:25 am   #3 (permalink)
sinex's Avatar
I want to fit the shark replacement flapper valve pipe, then remove the the cables and servo motor, I have spoken to 3 dealers now, non of them know if it will throw an error light, There must be someone out there with a termi 2-1-2 set up like ours that has gone this route, just need to find them!
Old May 7th, 2009, 3:54 am   #4 (permalink)
Monstaman's Avatar
You have found him ... me!
Your stealership can disable the flapper motor and o2 sensor in 5 minutes with the slipons ECU.
It really is as simple as connecting the bike to the diagnostics unit and getting into the correct settings area and disabling the flapper and o2.
Then you can disconnect your flapper motor at the plastic connector and remove the little brick from the bike.
Leave it in the shed or throw it at your neighbours, it is not a difficult task to do the disabling, you just need a stealership who KNOWS what they are doing.
Don't pay the stealership to learn, they should be compentant enough to do this and that is what you pay their big rates for.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old May 7th, 2009, 5:04 am   #5 (permalink)
Roulette's Avatar
I have the 308B ECU (termi 2-1-2) and have no error codes at all. I removed the entire flapper valve unit from under the seat.
As monstaman said as long as you dealership knows what they are doing, you can remove any error codes with the 308B ECU.
Roulette is offline   Reply With Quote
Old May 7th, 2009, 7:40 am   #6 (permalink)
Kinkykelly's Avatar
Same here for me. I put in my 2-1-2 and had the dealer set TPS and tune they disabled mine and I removed it when I got home. No problems, no codes.
Plus I put on a set of Zard headers, and tey remove the butterfly valve.
-KK
'06 Yamaha 50th Anniv. Edition (sold)
'07 CBR1000RR
'08 HM1100S
'11 Ducati Multistrada 1200S
Kinkykelly is offline   Reply With Quote
Old May 7th, 2009, 7:50 am   #7 (permalink)
Kinkykelly's Avatar
This is a picture of the Zard.
-KK
termi 2-1-2 servo/flapper-dsc00590.jpg
'07 CBR1000RR
'08 HM1100S
Old May 7th, 2009, 8:17 am   #8 (permalink)
Roulette's Avatar
KK that's one clean looking set of Zards.
Quick question for you or any other Zard owners.
Do your headers line up with bottom of the engine where the stock exhaust bolted to it?
Mine doesn't so I have not bolted it to the engine at all. Seems OK and I don't get any movement at all from them.
Old May 7th, 2009, 10:14 am   #9 (permalink)
sick50ford's Avatar
my hole was at least an inch off. i cut off the tab and welded a new one in place to pick up stock mount location
Old May 7th, 2009, 12:26 pm   #10 (permalink)
typhon's Avatar
Images: 9
ok. don't everyone think i'm ignorant; let me prove it to you
with this system, do i even have the flapper still installed
remember...i bought my hyper used with mods already in place, so i have no idea what was done previously. what exactly am i looking for
termi 2-1-2 servo/flapper-img_1130.jpg
typhon
Dyno shows that Termi DB killers kill more than just DB's. wasp1000 Sport Classic 23 May 27th, 2009 7:45 pm
2007 999s Termi Slip-on Help Please... makamogo Superbikes 14 Jan 13th, 2009 6:06 pm
the full termi is a DEAL at $2000 rubyvrooom HyperMotard 81 Jan 12th, 2008 12:38 pm
Advice needed 749 w/ Termi ECU? sludge Ducati Motorcycle Chat 3 Jun 8th, 2007 6:16 pm
