May 5th, 2009, 10:40 am
a flapper question for those with the 2-1-2 set up
Have any of you removed the flapper valve and servo motor from the loom and not got an error message?
May 5th, 2009, 11:18 am
with the stock ECU you will get the code, so leave it in, disable the valve, and just fake out the motor, there are many threads on this, Aloha Alex
May 5th, 2009, 11:48 am
yes, but I don't have the stock EC I have the 2-1-2 Termi EC, So will the 2-1-2 EC throw a fault? if the flapper and servo are removed, I am eyeing up the shark replacement flapper pipe, I could go for the blank plate on the servo, but I want all the junk removed
Reason: addition of text
May 5th, 2009, 12:29 pm
What if you change the ECU but leave in the flapper and the O2?
if you need to know... ask...
May 5th, 2009, 12:59 pm
Why change the ECU? the term 2-1-2 gets rid of the 02 sensor, and I belive disables the flapper valve, for the 3,5000 rpm pass by noise test, my objective is to dump the servo and the flapper valve for weigh and looks,
May 5th, 2009, 2:57 pm
Home of vortex tuning
The 308B gives you a choice using the O2 and flapper, programmable yes/no.
