Ignition Studs/Bolts: How do you remove them? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old May 2nd, 2009, 11:59 am   #1 (permalink)
oalvarez's Avatar
DISREGARD.....vice grips worked in unscrewing them. thanks
trying to fit the Dan Kyle Ohlins Damper Kit onto the HYM which requires removing/replacing the stock (shorter) ignition studs with longer ones (supplied). it's almost impossible to get any tool to the underside of the bolt, and in all honesty, i have no idea what the bolt fitment is (hex head? allen key head?) as i can't get a tool into the small space. i can turn the bolt from the topside using a small pair of vice grips at the base of the bolt but i can't think that this is the only way.
is double nutting it the only way to get it done?
i'm stuck. could someone please lend a suggestion or two?
thanks in advance!
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
oalvarez is offline   Reply With Quote
Old May 10th, 2011, 2:47 pm   #2 (permalink)
G2G
bump! I have the same question. I have had no luck removing these. Can anyone help us out here.
G2G is offline   Reply With Quote
900SS ignition tumbler shorting?? CJB Supersport 14 Mar 20th, 2009 3:53 pm
Czech "Ignitech" ignition system for old Ducatis Desmobloke Vintage 9 Aug 5th, 2008 8:22 am
Lost Key Update...How to remove 748 ignition...and a tumbler discussion. Mirek Superbikes 5 Jul 10th, 2007 1:56 am
Easier to remove...ignition or gas cap assmbly ? Mirek Superbikes 2 Jul 3rd, 2007 10:29 am
Ohms and Multimeter testing ignition coils questions Desmo Soundtrack Superbikes 4 Oct 9th, 2006 12:36 pm
