Full system - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old May 2nd, 2009, 7:09 am   #1 (permalink)
Full system
I bought a full Silmoto exhaust (without directions of course) and was wondering the exhaust sensor on the stock exhaust back by the cat....the full system doesnt a place to screw it into, do I just leave it unpluged? Does the Termi full system have this? I'm lost and need some help!
Viper1 is offline   Reply With Quote
Old May 2nd, 2009, 8:06 am   #2 (permalink)
Official Sponsor
desmoworks's Avatar
The termi doesn't need them because it comes with an ECU that eliminates the O2 sensor input. If you are planning to use the stock ECU then you have to weld a bung on to screw the O2 sensor into. It has to be used with the stock ECU.
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is offline   Reply With Quote
Old May 2nd, 2009, 9:51 am   #3 (permalink)
hyprduc's Avatar
Try and find a 2-1 ECU. They typically sell for around $300 unless someone is only in it for the money, then they're more. The cams ECU would work too but it is 18% richer than stock, mostly on the top end versus the 2-1 that is only 8% richer.
Hope this helps as I think it is a better and easier way to go than cutting and welding on your new exhaust.
Cheers
hyprduc is offline   Reply With Quote
Old May 2nd, 2009, 8:45 pm   #4 (permalink)
Would it have to be welded where both pipes come together or could I weld it on just one of the pipes?
Thanks for the help!
slip-on or full system? captdigi Monster 6 Apr 20th, 2007 8:58 pm
Heat Tape Needed, 50 mm Full System, 916? ducatimike Superbikes 8 Jan 20th, 2007 6:41 pm
