servo blank plate, what about - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Apr 30th, 2009, 1:45 pm   #1 (permalink)
sinex's Avatar
o.k so you fit the blank plate so the servo is sorted, you take off the cables, how do you get the valve out of the pipe and blank of the hole, ides appreciated
sinex is offline   Reply With Quote
Old Apr 30th, 2009, 3:15 pm   #2 (permalink)
Monstaman's Avatar
Angle grinder, brute strength and a tig welder.
You can either wrestle it out or simply cut the pipe sides of the valve end and put a straight pipe back in.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old May 1st, 2009, 10:27 am   #3 (permalink)
sinex's Avatar
Does anyone like staintune, LV just make the whole up pipe?
Dry Clutch Pressure Plate & Open Cover Installation Guide Rob998 Hall of Wisdom 54 Jan 16th, 2012 9:39 pm
1098 Clutch Plate Sequence medikateme Superbikes 8 Feb 4th, 2009 6:00 am
Fried clutch pressure plate DesmoBob Ducati Motorcycle Chat 9 Sep 16th, 2008 2:37 pm
Problems after installing a Pressure Plate on my 999s MixXxeR Superbikes 15 Jul 13th, 2008 12:56 am
Zero Dollar ($0) 749/999 License Plate Relocation glee719 Hall of Wisdom 5 Jan 11th, 2008 2:49 pm
